Truck hauler in Northern CA
Hello Everyone
I have a 68 C10 SWB that is 250 miles north of me that I need to go and pickup. I would drive it home but the brakes dont work. I dont know if its the master cylinder, prop valve, or broken lines I dont have time to troubleshoot it. I need to get it off of the property and back to my house. Does anyone know of a company that can tow it via flatbed or car hauler etc? Did a search and found a few that had the semi trailer but that wont work because this is in a rural area off of a gravel road. Thanks in advance!
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Re: Truck hauler in Northern CA
It's been several years since I've had a "project" like yours.. Here's what I did.. I went to U-Haul and rented a 3/4 ton truck and car hauler trailer.. Drove to the location, loaded up the vehicle and brought it home... Returned the truck/trailer to the same place I rented it.. I rented it based on time, not mileage, was cheaper that way....
![]() Join Date: Nov 2018
Rent a car trailer and go get it.
#4 | |
Thanks!
No rent the truck and trailer near you. Confirm they are available on the date needed. Drive up to pick up the truck and once back home return the truck and trailer locally.
Bring a come a long in case you need to winch the truck on the trailer. |
Born Psycho
![]() Join Date: Feb 2001
x2
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
At the body shop.
Roadkill trip.
" That didnt make it any newer " " Dont antique the equipment " |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Where is it exactly. I have trailer but need more info.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
I did that a while back but had a hard time getting the trailer. I told the first rental place what I was going to pick up and they would not rent the trailer to me saying my 72 long bed wouldn't fit. I went to another rental place and said I was hauling a mid 2000s SUV and they rented the trailer to me! Doh! Just FYI, my truck did fit.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
![]() Join Date: Jun 2022
I rented a U-Haul trailer for $45/day to drag my son's car back from SLO.
They hooked it up and I drove away, utterly painless
1970 C10 Custom longbed 350/350 |
No.. That's referred to as "One Way Rental".. More expensive because the rental fees are computed on mileage. Plus, agency loses the inventory.. Rent the trailer and/or truck locally and return it to the same agency.. The fees are then computed on time (daily)..
#12 | |
Just go and rent the truck/trailer, and take an overnight road trip. Don’t be afraid, because the U-Haul will provide you with all the straps and chains needed to secure the load to the trailer. Load the truck with the front first, to put the most weight forward of the trailer axles. One suggestion I would have, is to use Shoring Blocks under the frame, to cinch the load down onto a solid surface. This will prevent the load from bouncing while you drive. Just take your time there and back. |
Its just south of Redding CA. Going to San Jose CA.
Thanks for the suggestions. I am going to call up Ryder, Uhaul, Penske ETC ETC and see whats what. Will update the thread once I know.
