#126 |
![]() Join Date: Mar 2014
Re: "BUILD: 1970 C10 LWB--->SWB “Jumping Cholla”
Great looking build. I soon need to paint my roof, and am terrified as I am going to use an actual gun. Cant wait till its over. Good job on the seam sealer!
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
#127 |
Scott, the day you fire that up in the '70 let me know! I will bring some adult beverages so that we can enjoy that awesome first start sound!!!
Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
#128 | |
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
#129 |
Active Member
![]() Join Date: Oct 2012
New valve covers might be needed to clear a brake booster.......
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#130 |
Active Member
More progress this past weekend! We got the 700R4 temporarily bolted up to the back of the block and stuffed between the frame rails. The oil pan clears everything perfectly (I already knew it would as the BBC was pulled from a 1969 C10 when I bought it). The drivers side long tube slide in place with plenty of clearance. The Passenger side needed a little grinding on the upper and lower frame rails to get it to fit. I had to do the same grinding on the K5 as well. The drivetrain will get pulled again and the TC will get installed. When that is out, I'll clean up the grinding spots a little better and plug a frame hole that is really close to the trimming I had to do, then I put some touch up paint in those areas before putting the drivetrain in for the final time.
We threw the cab on the frame to make sure everything cleared on the firewall before final sanding and color. Plenty of clearance to the body, it's going to be close between the driver's valve cover and brake booster (which was the same issue I had on the K5, and it barely cleared it). Life is going to get busy for the next few weeks so C10 work will slow. We already removed the cab from the frame. Next up will be some plumbing for brakes, fuel lines, gas tank, and then exhaust.
#131 |
I can't wait to hear that thing come to life Scott! What are you going to do for wiring? Are you going to go with a new Painless harness or something else?
Clay
#132 |
Active Member
Ya, most likely a painless harness kit. I didn't even bother saving the harness I pulled out of the truck, it was so cut up and spliced. Looking forward to starting with something brand new and clean.
#133 | |
Clay
#134 |
Active Member
Not a very big update, but I have started blocking/sanding all the high build panels this week. So far I got through both fenders with 400grit and then hit them with 600grit. A picture doesn't do any justice for the work it takes to make a piece straight and smooth. Still have the doors, hood, cowl, and cab to get to.
I ordered a new SS brake line kit from https://www.inlinetube.com/products/sctb67d4 on Monday and it should be here next week. I still need a new master cylinder and booster, but I'll hold off on those until I get the painted cab back on the frame for the final time. I have been flip flopping on the gas tank fill config (top or side) and think I'm going to go with the side inlet. I'm going to steal the gas tank filler door from the blazer and graft it into the side of the C10 SWB bed (that I still need to cut down from it being a LWB ![]() Next week I'll probably stop by Speedway Motors and pick up a 3" exhaust tube builders kit and some mufflers to start laying that out soon.
#135 |
Hey Scott, so you started with 400 grit on the high build? Did it eat through it quickly? I was going to start with 320, but I am not thinking that may be a bit to aggressive.
Clay
#136 |
Active Member
The 400 grit felt good to start with on the big areas with my block. I was worried 320 would take too much to start with. I did use some 320 grit Duro-Gold pads wrapped around a 1" round Duro block for the inner corners/radius parts of the fender. Those seemed like it took off just as much the PSA 400 grit paper. For the 600 grit, I used the same Duro-Gold pads with a block behind it to finish all the areas of the fenders.
#137 |
Active Member
After spending the evenings of the past week sanding panels, I finally got to spray some color yesterday morning
![]() This morning I'm shooting the white on cab roof and door window frames. Tomorrow I'll tape off those areas and spray the bottom of the cab and the rest of the doors, cowl, and underside of the hood with color. Sunday I'll finish off the top of the hood. At least that is the plan ![]()
#138 |
![]() Join Date: Jun 2002
Nice! It's gotta be a great feeling to get some paint sprayed on. Great work, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
#139 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Truck is really coming along nice.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#140 |
Cool color!
#141 | |
Active Member
#142 |
Active Member
It's a white xmas in July! Just shot the white and it's looking good. I do have a few runs on the top of the window frames from trying to get the very thin frame top covered in white. I didn't notice any run on the roof. I'll pull the tape/paper in a little bit and then it can bake in the garage all day.
Tomorrow morning will bring some more color
#143 |
You are doing a hell of a job Scott! The color looks great!
#144 |
Awesome job, very nice color.
#145 |
Hey Scott, it was great seeing you again yesterday. The truck looks awesome! Thank you for the pointers as well. :-) The offer of beer and pizza still stands if you wanna come and paint mine!
Clay
#146 |
Active Member
Thanks!
It was great seeing you again, thanks for stopping by the sauna and looking at the truck.
#147 |
Active Member
Continued painting progress... Friday night I started to tape off all the white on the top cab and top door frames.
Saturday was an early start @ 5am to finish off taping the bottom of the cab so my raptor liner didn't get over sprayed. I lifted my cab dolly off the ground an extra 10" with some blocks to help me get good coverage on the bottom sections of the cab, which helped out a ton. I finally started shooting some paint around 7am. 2 hours later I had 3 color coats on the cab/doors and 4 coats on the hood. After things dried a little bit more, I pulled off all the tape/paper and was really happy how things turned out. I let everything bake in the garage the rest of the day.
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed Last edited by loudchevy; 07-07-2024 at 11:37 PM. |
#148 |
Active Member
This morning I started sprayed the cowl with some color. It was nice to not have to tape anything! I had a couple of small runs on the vertical side of the cowl that will need to be wet sanded down, but it turned out good.
Once the cowl dried for a bit I moved it out of the garage and started to clean up from the last 4 days of painting. I got the cab dolly off the blocks and moved the doors and hood to inside the house. I have C10 body parts all over my house now ![]() I really wanted to see the cab sitting in the sun. I think it turned out fantastic. I'm really pleased how it came out being my first paint job and using an $80 gun for all the primer and color. The 2 tone cab looks awesome, the Championship White really pops. My favorite part might be the shaved firewall. I had countless hours of welding, grinding, sanding, and bodywork invested in that mini project and it was rewarding to see it in color. Really seeing everything in color just makes me smile. I still need to chop the bed and do all the bodywork on it. I learned so much from doing the front half of the truck and I know it will help speed things along with a shorter learning curve to finish all the bodywork for bed. I used almost a quart of the Championship White and have maybe 1-1/2" left in the Frost Green Metallic gallon. I used the whole quart of the UR85 Slow Urethane Reducer which was perfect for spraying in the garage where temps were easily over 90 degrees even at 7am. Grand total for paint on the front half of the truck was $432
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed Last edited by loudchevy; 07-07-2024 at 11:39 PM. |
#149 |
![]() Join Date: Dec 2009
Very Nice
![]() If you have any Gearhead neighbors? I know they were Impressed. ![]()
#150 |
Dang, that's sharp!
