Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 06-25-2024, 03:40 PM   #1
87Skier
87Skier's Avatar
How does fuel pump cutoff work?
Hey everyone,
I'm working on wiring on my 72 Jimmy with a 2013 4.8L engine, 6L90e transmission, and e38 ECM. Before I wrap everything up, I am considering putting in an inertial fuel pump cutoff. Like this one: https://www.rockauto.com/en/moreinfo...=10756&jsn=667
But is this even necessary for this setup? My fuel pump relay is triggered by the ECM, so does the ECM disable the fuel pump after a crash? I know the later generations of trucks switch to a Fuel Pump Control Module, but I'm unsure of how my ECM works.
Any insight from owners of these trucks or engine swaps would be very helpful. Thank you!
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 07-06-2024, 02:05 PM   #2
Richard
Re: How does fuel pump cutoff work?
Might be some other features if in a car with impact sensors and such, cannot say for sure. The most basic feed from the ecm is the fuel pump would be energized for a prime cycle. The ecm would also shut off the fuel pump if the engine is not running.
Richard
