Power steering replacement
The power steering system on my 72 c10 was leaking since I bought it. I put some stop leak in it and filled it up as needed for a while. Finally it blew a seal out of the steering gear, so it was time to address the issue.
I read some posts on this site, and it looked like getting a new steering gear was the way to go. I also replaced the steering pump/reservoir, both hoses, coupler, and added a filter on the return line. I got all the parts off Rock Auto. I had to verify input shaft diameter and spline count as there were multiple steering gears to choose from. Install was pretty easy until I got to the hoses. I tried to pick the hoses that looked like my originals. The fittings were correct, but had to do some bending of the metal lines to get them to fit properly. Really happy with the results. My original steering gear was 4.5 turns lock to lock. My new one is 3.4 turns lock to lock. The quicker steering is noticeable on corners and roundabouts. The steering was too light before, it has more feel to it now. I’ve also noticed that it drives much nicer at highway speeds, less wandering. It feels like a more modern vehicle now. |
![]() Join Date: Jul 2000
Re: Power steering replacement
Good job! And good luck finding hoses that don't need a little bending. I went through three, and they were almost identical. I think power steering trucks must have a slightly different inner fender bend than manual steering trucks. I had to massage my inner fender to get a bigger gap between it and the frame.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
novaX522, 2 - 3 years ago, I went through the same hose difficulties.. I installed power steering where previously there was none. I got everything mounted and the hose search began.. The listed hose wouldn't fit and I tried hose after hose.. Edlemann pressure hose was the best fit after a bit of tweaking.. The part number is EDL-70911..
About that inner fender panel.. I had to cut away a section for it to clear the gear box.. To add stiffness, I turned the edge down along the cut.. A paint job finished it off. |
![]() Join Date: Nov 2018
Everything is made elsewhere now days so I'm sure the QC key word was 足够好....that's "Good Enough" in Chinese.
#5 | |
#6 | |
Pain in the arse, but that’s the price for having a cool truck. 😎 |
#7 | |
I used this brand on my 72 fit was perfect didn’t need to bend anything return line I just replaced the rubber hose kept the original hard piping.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#9 | |
I have about 1/8” of clearance from the inner fender well |
