Old 03-19-2024, 09:56 AM   #51
Tempest67
Tempest67's Avatar
Re: 1958 Pontiac Wagon Build
Hey Guys,
I installed another patch (under rear seat) and have the rear driver's side floor (footwell) piece to go. (last one)
But, on another topic, I had a friend of mine make me some custom wheel center inserts for my Pontiac Rally 2 wheels. Instead of the PMD, I am going to use these. I was able to hide the lines/grooves made by the 3D printer with many coats of clear.
Tempest67 is offline   Reply With Quote
Old 03-19-2024, 03:01 PM   #52
HO455
HO455's Avatar
Those are sweet!
RIP Bob Parks.
Old 04-01-2024, 09:18 AM   #53
Tempest67
Tempest67's Avatar
I installed the last piece to the floor. (Rear Drivers)
I did not grind the welds smooth on the inside, as I want to keep the strength of the weld, and once the carpet is down, it will not be seen.
The underside of the welds need more smoothing, but that will be done when the body is lifted off the frame. (as I can't get at the welds) Also have some edges to weld in and smooth around the rockers/rear wheel wells, but that will be done when I remove the wheels/body.
Overall, I am pleased with the results.
Old 04-02-2024, 01:33 AM   #54
3drburb
That is a lot of work and it looks great from here, good choice on leaving as much weld as possible on the floor.
The dash profile and gauges layout is really cool.
Thanks for showing as always and looking forward to see what's next.
3drburb is offline   Reply With Quote
Old 04-03-2024, 11:46 AM   #55
Tempest67
Tempest67's Avatar
Thanks 3drburb
It has come a long way, but still a long way to go.
Old 05-29-2024, 11:40 AM   #56
Tempest67
Tempest67's Avatar
Hi Guys
I have been busy with some home renos for our daughter but was able to work on the Gas Tank.
I thought it would have been as rusty inside as out, and was preparing to pay $500 for a new one, however, after removing a few rocks, and a vinegar/water sloshing, it looks really good inside.
Then I had to make a steel piece to weld to the new sending unit (came with new fuel gauge) to attach to the tank.
The tank now has about a pint of Transmission/Varsol solution that I slosh around occasionally (will be emptied at time of install) and is waiting.
1 more thing done (on a long list)
Old 06-02-2024, 08:37 AM   #57
7dee2
7dee2's Avatar
Good job on the floor repairs and a nice save on the gas tank looks good!
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 06-04-2024, 09:15 AM   #58
Tempest67
Tempest67's Avatar
Not a big job, but I found some old PMD wheel centers at a Swap Meet and installed my custom inserts.
So the wheels just need some trim rings, lug nuts, and tires.
Old 06-06-2024, 09:21 AM   #59
Tempest67
Tempest67's Avatar
Another little job, I am planning to use a 'Vintage Air' style of heater, so I decided to make a Blower Motor/Heater Core delete plate to clean up the fire wall.
Old 07-10-2024, 04:42 PM   #60
leegreen
You are doing a great job saving that wagon and have no reason to be dissing your own metal working skills!
I like the one section at a time approach, it does not end in a shell suspended in a web of cross bracing with no floor at all being sold with the 'all the hard work is done' byline.
By the looks of that body you could switch from floors/frame to driveline and then drive it with exterior bodywork as-is. A reward period to rejuvenate your enthusiasm for continuing.
What are your plans for rust proofing inside those newly rebuilt floor braces ?
leegreen is offline   Reply With Quote
Old 07-10-2024, 06:00 PM   #61
Tempest67
Tempest67's Avatar
Thanks for the kind words, but my metal skills will be really tested when I start on those quarter panels.
I did brace the doors when I did the rocker panels, as the X frame has no support there, and the doors still open and close without an issue.
I coated the inside of the braces with that 'stone guard/bedliner' stuff but soon found out it was flammable when welded, so I simply painted them and will follow up with somekind of paint sprayed in with a blow gun.
A Home Reno project and the summer heat has slowed progress lately, but I am looking forward to getting back at it.
Thanks again
Old 07-10-2024, 06:56 PM   #62
HO455
HO455's Avatar
Nice job on your heater delete plate. Did you use a MDF die to form the piece?
RIP Bob Parks.
Old 07-11-2024, 09:25 AM   #63
Tempest67
Tempest67's Avatar
not sure what an MDF Die is, but I used a cheap Bead Roller with the 'step dies'.
I used the same bead roller to make the beads for the floor pieces, but with the round dies. (tried to duplicate the factory design)
Old 07-11-2024, 09:59 AM   #64
HO455
HO455's Avatar
This guy does a good job of explaining how to use MDF to hammer form pieces. Never having had a bead roller I made a couple little covers in the past using MDF for a die.
https://youtu.be/oPgeZX46QTE?si=MaotjeF6bR9RQ7bR
RIP Bob Parks.
Old 07-11-2024, 12:10 PM   #65
Tempest67
Tempest67's Avatar
Oh OK, I know what you mean now. Making the wood 'dies' is alot of work, I waited for this cheap bead roller to go on sale ($200?) and it has been useful when needed. (Princess Auto is the Canadian version of Harbor Freight)
I know it is a cheap Chinese tool, but for what I am doing, it works fine.
https://www.princessauto.com/en/18-1...t/PA0008536773
That guy in the video is a VERY talented
Old 07-11-2024, 12:46 PM   #66
bnorth
Japhands is very very skilled, and a fellow Canuck!
Great work so far, I am enjoying following along. I can see the improvement in your bead rolling on the passenger side after you did the drivers side.
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
Old 07-11-2024, 01:13 PM   #67
Tempest67
Tempest67's Avatar
Thanks bnorth, the hardest part is making a straight line
Old 07-12-2024, 08:17 AM   #68
HO455
HO455's Avatar
I saw this ad and immediately thought of you.
https://medford.craigslist.org/pts/d...755407194.html
RIP Bob Parks.
Old 07-12-2024, 09:33 AM   #69
Tempest67
Tempest67's Avatar
Thanks, I like it.
$2000 for both cars! great potential there
Old 07-12-2024, 09:47 AM   #70
leegreen
Have you modified the bead roller at all? I have the same thing, it works, but it works much better if you stiffen the two arms so they can't scissor back and forth. And a steering wheel makes it a lot easier to use than the crank
Old 07-12-2024, 01:18 PM   #71
Tempest67
Tempest67's Avatar
Hey Lee,
Yes I welded some angle iron to each arm, and drilled holes to insert pins to keep the arms together. The pins can be removed when working with wider pieces.
I still use the crank, but a wheel would be nice..... but I really don't use it that often.
Old 07-18-2024, 11:25 AM   #72
Tempest67
Tempest67's Avatar
Hi Guys, Quick update, not very exciting, but it is something to get accomplished in this heat.
I picked up some pulleys and brackets that needed some paint, so I gave them a quick coat.
I have found that this formula provides a good hard finish when dry, and it allows me to add flat black, or gloss black, to give a variety of different sheens under the hood. I have heard that more hardener will 'flatten' the sheen as well, but I am still experimenting with that. ( 3-4 parts paint, 1 part Acetone, and .25- .5 Hardener )
also, for you Americans, the paint is just a Canadian 'knock off' of Rustoleum.
Old 07-24-2024, 11:39 AM   #73
HO455
HO455's Avatar
Thanks for posting this. I've got the paint and acetone just need to pick up some hardener and I will give it a try.
RIP Bob Parks.
Old 07-24-2024, 01:38 PM   #74
leegreen
you may need a slower solvent than acetone on a hot day,
acetone fast
lacquer thinner med
toluene slow
is a rough guide
it is worth testing under expected conditions
Old 07-24-2024, 04:02 PM   #75
Tempest67
Tempest67's Avatar
I hope the formula helps as I am still experimenting, but I painted the radiator core and inner fenders last Fall and I am very pleased with how hard and durable the finish is. (and cheap)
Like I said, I like looking under the hood and seeing all the different "semi gloss" black finishes on the different items.
