Any ideas on how I can stop column shift linkage hitting brake booster on my 6810?
I have a custom power brake booster mount bracket on my 1968 Chevy C10 shortbed which puts the booster closer to the firewall and i also installed a brand new Tuff Stuff 9in booster TFF-2224NB when I converted my truck to 4wheel disc brakes. As most know the factory booster bracket sticks out from the firewall a good distance but I have never liked that but at least it wouldnt have caused the problem I am having now.
My 68 is originally a 396 engine with 400 turbo automatic and column shift. There is a very long shift rod that is attached to a shift lever down at the trans then goes up near the power brake booster to a lever there. The problem is that the shift lever on the column is hitting the bottom of the brake booster. My temporary fix was to rotate my column so I could at least get it in some gears but it is very difficult getting it into park and now the gear selector on the column is not reading correctly which I knew would happen. The shift rod and lever look to be factory and so does the entire steering column. Ignore the position of the shift rod in the pic because I already adjusted it down but now the shift lever itself hits the booster. Anybody have any good ideas on how I can make my current set up work? Maybe there is a different factory C10 column that puts the shift lever lower on the column and would clear the booster? Is there a way to somehow push the column down further so that the shift linkage does not hit the booster? Last edited by HeavyHauler; 07-10-2024 at 07:22 PM. |
![]() Join Date: Feb 2016
Re: Any ideas on how I can stop column shift linkage hitting brake booster on my 6810
Why not trim the end of the rod? Cut it around where the green lines are. Seems to me to be simple and cheap. Do a clean job and repaint and it's unlikely anyone will ever notice.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Nov 2018
^^^^^^^^^^^^^^^What HO455 Said^^^^^^^^^^^^^^^^
![]() Join Date: Feb 2022
Agree. Is the rod the only thing hitting. Seams simple to me. One of the most useful tools in my tool box is a cut off tool. Go to harbor freight and pick one up along with a pack of wheels and eye protection. It will make the job under 5 minutes including clean up and finding a place to store the tool.
#5 | |
Are you saying instead of adjusting the rod lower that simply cutting the rod would work? By adjusting that rod lower did I misadjust the gear shift lever? if you look at my shift lever it is also very close to the booster will be able to only move up and rest on that detent bump located on the shifter plate which has the detent that separates reverse and park position before the lever hits the bottom of the booster and when it does my shift lever is right on top of the detent bump on that "shifter detent plate" Last edited by HeavyHauler; 07-10-2024 at 11:48 PM. |
#6 | |
![]() Join Date: Mar 2003
I'd put the right brake booster and bracket on, but that's just me putting parts on that were designed for the truck
![]() ![]() Join Date: Jan 2005
There is a collapsible slip joint at the bottom end of the steering shaft that is held in place by plastic pins. Some people like to drill out these pins so they can collapse the joint and move their steering wheel closer to the dash to improve driver comfort. Maybe performing this modification would allow your shifter linkage to clear your brake booster by placing it in front of the booster. I'm having a hard time telling from your photos how far forward the shifter linkage would have to move. Taking some measurements first would help to determine whether this would work.
#9 | |
I was just trying to see if I was missing anything that would make my current setup work before having to switch everything and buy all new parts again. |
#10 | |
![]() Join Date: Jun 2022
Could just use a dual-diaphragm booster, or go hydraboost
1970 C10 Custom longbed 350/350 |
Is there another year of C10 steering column or other truck column that puts the shift lever lower on the column?
Switching out the column would be alot easier than swapping out my booster, mastercylinder and lines, rear discs and everything then having to bleed the system again and figuring out what brake rod I would need. Losing my rear disc brakes not to mention the cost of buying everything again. |
![]() Join Date: Feb 2002
Have you looked into a Hurst or B&M floor shifter, and changing the Column to a Non-Shift type?
Possibly move booster out 1.5 " and change brake pedal push rod.
