![]() Join Date: Feb 2022
OER vs Dynacorn Windshield Trim
I was polishing my windshield trim, prepping for install, and the wheel grabbed my left side piece bending it all to heck. I really know better. Searching available parts...Looks like OER is back ordered most places. I am not a fan of OER parts. Most everything branded OER I've purchased has gone back for fitment issues. Dynacorn site says it is OEM, but I've never ordered from them. Can I get input from those who have used Dynacorn?
![]() Join Date: Feb 2009
Re: OER vs Dynacorn Windshield Trim
The aftermarket windshield trim is garbage at best, does not fit. You are better off to find another original piece sorry
I see posts that say install was a nightmare and I see post that say it went right in no problem. The common factor for an easy install seems to center around use of lube. I don't see much about the trim causing issue. I posted a WTB on the parts board. Maybe I'll get lucky and someone will have an OEM piece collecting dust they want to let go.
#4 | |
You have any details or links to the "use of lube" comment? Is that with respect to the glass/gasket or the trim? Gonna be replacing glass with trim in less than a week. -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
![]() Join Date: Dec 1999
Lube is not for the trim. Once it's in the weatherstrip it's fine.
I bought the Precision water based lube to use between the gasket and the windshield and then just squirt water on the truck to lubricate the truck to gasket side. |
Correct. I suspect it may also assist some in getting the trim fully seated prior to roping in the assembly to the truck. I've never installed a windshield. I talked with a tint shop a while back. They said leave front and rear glass out, and vent window handles off. They will install the windows after they lay on the film. 500 for everything and said they had lots of these old trucks under their belt.. Seemed fair price.
#7 | |
For comparison to your number... I was quoted $434 today for glass install. They're providing gasket (Precision) and glass and reusing my trim. It's a mobile service recommended by a speed shop I trust. Job will get done next Tuesday. This is 100 buck more than I paid last time when I supplied the gasket. -Kevin
Thanks for comparison Kevin. I will provide Persision gaskets, trim and glass. They will provide very light tint film and instalation. There are probably lower price shops but I got the feeling these guys had the process down and were not afraid of a newly painted old vehicle.
![]() Join Date: Jan 2011
I used the generic brand of KY, on the cab opening, and in the windshield slot in the gasket. Definitely nowhere close to the trim..
KY is water based, so it will just dry up where petroleum based lubricants would kinda mess with the paint. It won't get all over the dash like a spray either.. Worked like a charm. QTips help a lot to get the KY stuff into the windshield slot in the gasket. I used a Precision gasket and aftermarket trim and wouldn't hesitate to try it again. Just my .02.
I have some extra stainless trim for a windshield. PM with details of what you need. Ironic that I am also polishing trim for my windshield install on the 24th.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
A follow up on the windshield trim. I few members offered some pieces but it just wasn't coming together so I had GMCPauls send me a set. Shipping was pricey but I felt it was the best option without spending more time on an original part. Net result.
AVOID at all cost the aftermarket windshield trim. I received the trim next day drop shipped from dynacorn. To the untrained eye, I was impressed and thought I got lucky. That was until I went to mount into the Presision seal. If you must go with aftermarket trim be prepaired for the fight of your life and you will need a helper just to get the trim to seat. I did not have a helper. Spent 4 hours and could not get the upper ssection to fully seat. The arc was just off enough to cause rotation and seal to roll out of position before I could get the opposite end to fully seat. The following day I tried again and gave up after a hour. Pulled out the original part and hand polished for about 30 minutes. Looks 90%. It mounted into the seal in about 5 minutes work. The side/lower Dynacorn piece was difficult but did seat. It did not seat as easy as original. I ended up using just the one side dynacorn part for the one I carelessly damaged. The other side and upper pieces are original. The look is good. The rear aftermarket was difficult but did seat much better providing good result. Bottom line, the rear is easily replaced with aftermarket. The front, avoid aftermarket at all cost. |
#12 | |
![]() Join Date: Apr 2013
1966 C10 Mary 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
