![]() Join Date: Sep 2002
Oil Filter Adapter
When disassembling the reman block in the 68, it had this kind of filter adapter. I assumed it was original to the truck and transferred to the new block. It has a GM casting number on it. Did the 68's have the canister style or spin-on filter? Was this an adapter to convert to the spin-on style?
Why couldn't have the more modern adapter worked? Is it because it had a canister filter? I really don't understand how the canister type works compared to the spin-on type. I thought to convert to a spin-on, the later style adapter was all that was needed. Can anyone educate me on it?
1966 C10 Custom Cab Restomod (Sold) 1969 Camaro Z/28 (Keeper) Current Build: 1968 C10 (Semi-Factory Restoration) 1983 Camaro Z/28 (Next in line, Keeper) 1951 3100 (2nd in line) Last edited by damnyankee36; 07-06-2024 at 12:06 PM. |
Who Changed This?
![]() Join Date: Jan 2013
Re: Oil Filter Adapter
'68 was the last(?) year for the canister type filter. Fram made an adapter that used a Ford oil filter. This was because the gasket is on a smaller diameter than the spin on Chevy filter. If the engine you're going with doesn't have a provision for the canister type filter (it would just be flat, no groove) you can use the regular Chevy filter.
![]() Join Date: Feb 2002
1968 must have been a transition year. My '68 C/10 Stepside out of Fremont had a factory RPO L25 -- 292 L6 with a spin-on PF-35. I now use Wix 51061.
Who Changed This?
Pretty sure that the 4- and 6- cylinder engines had the spin-on filters since Chevy went away from the 235 engine in '63.
Been a long time but I had a 327 that was pulled from a '68 Impala in the mid '80s. I just added the spin-on adapter I thought?
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
That's actually a good adapter, uses factory bypass valve. Many 283s, 327s used them by POs.
Canister gets you a larger filter, and if headers are close, protection from heat. Need oring for internal piece with bypass, and canister. These canisters are dirt cheap at swap meets every where.. Last edited by 1967GMCC20; 07-08-2024 at 10:22 AM. |
Who Changed This?
They are also more efficient, and as much fun to clean as an oil bath filter. If it were my guess, Chevrolet did away with that design because of the nuisance of changing that o-ring every time. If you don't change the o-ring, things can go very wrong. I learned that at the age of 15 when I changed the oil in my eldest sister's '57 Plymouth, and left the old ring in because I thought it would be OK. I know that I didn't like that style, and I've done hundreds of oil changes since then.
I'd bet they replaced them for same reason manufacturers make changes.
Significant Cost Savings... Somebody's grandfather got promoted. Less parts. Cheaper. Lighter. Ease of assembly. Faster Tac-Time. |
Who Changed This?
^ Yup, I'll bet just putting the newer style filter on saved a ton of time. GM keeps track of component costs to the 1/10 of a cent, at least they did in the '60s. Don't groove the block for the o-ring? Time savings. Same goes for all those filter parts and installation time. Do it a million times a year?
Right on, having worked for a large Diesel Eng Manufacturer, to be competitive, you have to keep cutting costs soon as your in production after final design approval.
In small engines look at history of MTD.. the masters of small engine products cost reduction. |
My '69 C20 with a 350 that I bought new has a canister.
![]() Join Date: May 2010
Same with my '69 C20 which I also bought new. I always wondered if the reason was that the truck is a 3/4 ton.
Jim |
![]() Join Date: Apr 2016
My 69 CST/10 with 350 came with a canister filter. My engine rebuilder converted it to spin on when he rebuilt the engine for me.
My 67 with its original 283 has this same adapter. It was leaking a bit when I got the truck running so I got a new one because I could not find seals listed for the one on the engine.
I've had at least three modern Toyotas with canister filters. Highlander, Tacoma, and 4Runner.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#15 |
I'm going to guess the canister blocks were machined differently than the spin on? The block adapter was installed on a modern block and it appeared work OK.
They didn't have to use the adapter as far as I can see.
1966 C10 Custom Cab Restomod (Sold) 1969 Camaro Z/28 (Keeper) Current Build: 1968 C10 (Semi-Factory Restoration) 1983 Camaro Z/28 (Next in line, Keeper) 1951 3100 (2nd in line) |
#16 | |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
#17 |
Who Changed This?
You are correct. I deleted my response, was above.
#18 | |
Personally, I prefer the canister. More filtering area even though they are a pain in the a** to change. Below are a couple pics of the differences. Bigger pic is canister block. Smaller pic is spin on filter block.
John 1967 C20 2WD Longbed 2001 2500 HD 4X4 Extended cab long bed ![]() |
#19 |
There are two styles of aftermarket spin on oil filter adapters for 1956-67 Chevrolet V8 engines originally fitted with canister filters. The first style that you have is used in conjunction with the stock canister style bypass valve and uses a Chevrolet type spin on filter. This design relies on a felt washer to seal the adapter to the bypass valve. If the felt washer fails unfiltered oil will bypass the filter. Even worse pieces of the felt washer can come off and travel directly to the engine bearings. I never use this style of adapter.
![]() The second design is the one I prefer. It uses a Ford style spin on filter. These filters have a built in bypass valve so there is no need to use the old canister bypass valve. To install this adapter you simply remove the old bypass valve, bolt the adapter directly to the block, and spin on a new filter. There is no felt washer to worry about and it uses a Ford-Chrysler style spin on oil filter which has the bypass valve built into the filter. This adapter is simple, safe, and uses the most common filter on the market. Trans-Dapt 1024 adapter ![]() Last edited by Stanco; 07-15-2024 at 03:32 PM. |
#20 | |
![]() ![]() Join Date: Apr 2022
68 Small blocks are a oddball in themselves as they were a transition year. mid 59-67 are all pretty much the same then 69 and later are all pretty much the same.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
#21 |
Who Changed This?
Thus my (?). I worked as a mechanic in those days, but don't recall all those details. I see people claiming '69 was the first year for spin on filters, too. A lot of time has elapsed since then, and memories fade.
#22 |
I can see people thinking that with 69s as there was alot more visual change to a small block over a 68, but I have mainly messed with 68 327's for the last 15+ years now and yeah there could be a whole thread on how 68 engines are oddballs.
If you want another form of confirmation, if you look up older parts books for like Fram/Wix (Wix's online search still shows it right now as well) but if you look up a 68 327 it calls for a spin on, then look at a 67 327 and its a cartridge type.
#23 |
As far as I know, 1968 and later blocks were machined for the spin on filter. This was one of the few changes to the architecture of the small block including bigger main bearing bores.
If you have a later engine with a canister, it has the special adapter to use a canister on a spin on block. These were available as an option on police, taxis, heavy duty trucks and certain marine applications. The GM part number is 3959104 for this special adapter. .
