Old 07-13-2024, 01:52 PM   #1
JDarby
Active Member
rear sway bar removal on a C4 flatout 55.1GMC-100
All,
On my build I have had to remove my rear sway bar in order to install my gas tank.
My builder says it should be ok and not cause me any issues and I am wondering what you all think about that?
Here's my build spec to date:
6.0L / 4L80e
C4 FlatOut IFS / IRS
55.1GMC-100
We would have to re-design a sway bar to work with the C4 vette rear end in my frame. Because of the hidden Hagan fuel door in the fender and the
position of my tank, I need to keep that in place.
Open to all thoughts and ideas, thanks in advance!
1955.1 GMC 100 RestOMod
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
JDarby is offline   Reply With Quote
Old 07-13-2024, 04:14 PM   #2
LS short box
Re: rear sway bar removal on a C4 flatout 55.1GMC-100
I think I would finish the build and see how it handles.
On the other hand there is a company out in CA that helped me with a custom front sway bar for my 67 Nova project.
They are Speed Engineering. They do mostly race car stuff. Maybe they could help?
Old 07-14-2024, 12:37 PM   #3
JDarby
Active Member
Thats what I've been thinking!
If the sway bar is an issue with my driving style I will seek the help of a race car specialists!
With the fuel tank in place and my hidden fuel door in place I do not want to go backwards to save the sway bar at this stage of my build!
Thank you LS Short Box,
I'll put "Speed Engineering" of CA in my back pocket!
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
Old 07-17-2024, 04:09 PM   #4
LS short box
I may of misspoke. It may be Speedway Engineering.
Old 07-23-2024, 03:26 PM   #5
SCOTI
SCOTI's Avatar
Correct. I used them for the front bar on my '64 project.....
https://1speedway.com/?route=common/home
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
