07-13-2024, 01:52 PM | #1 |
Active Member
rear sway bar removal on a C4 flatout 55.1GMC-100
All,
On my build I have had to remove my rear sway bar in order to install my gas tank. My builder says it should be ok and not cause me any issues and I am wondering what you all think about that? Here's my build spec to date: 6.0L / 4L80e C4 FlatOut IFS / IRS 55.1GMC-100 We would have to re-design a sway bar to work with the C4 vette rear end in my frame. Because of the hidden Hagan fuel door in the fender and the position of my tank, I need to keep that in place. Open to all thoughts and ideas, thanks in advance!
1955.1 GMC 100 RestOMod 1972 T120RV 1967 C200 Trail 90 2014 TRD Quad CAB |
07-13-2024, 04:14 PM | #2 |
Re: rear sway bar removal on a C4 flatout 55.1GMC-100
I think I would finish the build and see how it handles.
On the other hand there is a company out in CA that helped me with a custom front sway bar for my 67 Nova project. They are Speed Engineering. They do mostly race car stuff. Maybe they could help? |
07-14-2024, 12:37 PM | #3 |
Active Member
Thats what I've been thinking!
If the sway bar is an issue with my driving style I will seek the help of a race car specialists! With the fuel tank in place and my hidden fuel door in place I do not want to go backwards to save the sway bar at this stage of my build! Thank you LS Short Box, I'll put "Speed Engineering" of CA in my back pocket!
07-17-2024, 04:09 PM | #4 |
I may of misspoke. It may be Speedway Engineering.
07-23-2024, 03:26 PM | #5 |
Correct. I used them for the front bar on my '64 project.....
https://1speedway.com/?route=common/home
