#51 |
BMW & ASE Master Certified
Re: Big Brakes with OE Rotors and OE Brembo 4 piston calipers
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
#52 | |
At the body shop.
" That didnt make it any newer " " Dont antique the equipment " |
#53 |
#54 | |
cpp 2.5 modular drop spindles 12-20 jeep GC srt8 6.4L CENTRIC rotor 12158010 (380mm) center hole needs opened up to about 3.07in Kore3 billet hubs for c10 hd 1.25 rotor 10-15 camaro 4 piston calipers brake lines are the same fittings, might have a different flare though. bolts for the brackets. ill try to get you those too give me a bit. or just order them from cpp the caliper bracket to spindle. they come with the brackets for stock d52s. if i was to do it again. i would get the x10 cpp spindles and then i would see if the jeep gc wheel bearing hubs would fit them and them use factory rotors without mods and see if the same bracket works or not. |
#55 |
Explorer
![]() Join Date: Jul 2021
Older than Some and Younger than Some, but I am still here ![]() ............... ____ .. ________//__{\____ /__(O)___//___/_(O)_/ |
#56 |
At the body shop.
the jeep rotor have a deeper hat than the ss camaro stuff ?
Our camaro stuff needed a 3/8 spacer to clear the caliper with 18in rocket attack wheels
#57 |
Been looking into doing this setup on my truck.
Curious whats the minimum wheel size to clear the calipers? |
