Old 07-13-2024, 10:17 AM   #1
blazerowner71
Active Member
Wanted 67 nos door handle
Wanted 67 only nos drivers side exterior door handle, the body shop was supposed to modify the door to fit the 68-72 handle, when I tighten the bolts the handle tilts and leaves a gap at the top of the handle, any help would be appreciated, thanks Adam
blazerowner71 is offline   Reply With Quote
Old 07-15-2024, 10:25 PM   #2
blazerowner71
Active Member
Re: Wanted 67 nos door handle
Ttt
Old 07-16-2024, 12:09 PM   #3
pjmoreland
pjmoreland's Avatar
https://www.ebay.com/itm/20462518650...3ABFBMyITJxJdk
pjmoreland is offline   Reply With Quote
Old 07-16-2024, 07:38 PM   #4
blazerowner71
Active Member
Thank you do you know if the part number is correct for a 67 only handle
Old 07-16-2024, 09:55 PM   #5
pjmoreland
pjmoreland's Avatar
The part number on the box is correct for 67 only. I don't know about the casting number on the back of the handle though.
Old 07-18-2024, 12:08 AM   #6
blazerowner71
Active Member
Thank you I asked for better pictures but never got any
Old 07-18-2024, 01:10 AM   #7
chewychevy67
The casting number on my original 67 handle does not match the one on his.i suspect a 68-72 handle he has there.
chewychevy67 is offline   Reply With Quote
Old 07-18-2024, 09:01 AM   #8
blazerowner71
Active Member
Thank you
Old 07-18-2024, 12:33 PM   #9
72ironmike
72ironmike's Avatar
Even though the casting # is different it may be 1967 correct. Ask the seller if the bolts thread straight in or at an angle & you will get a positive ID.
72ironmike is offline   Reply With Quote
Old 07-19-2024, 07:52 PM   #10
blazerowner71
Active Member
Thanks Mike the seller is not responding
Old 07-21-2024, 09:34 AM   #11
Jason Banks
Jason Banks's Avatar
I'm pretty sure Key Parts make a repro 67 only door handle.
See here: https://www.ebay.com/itm/155569362173
I bought a set a while back but have not installed them. When I get to my shop. I'll try to take a picture to confirm they are correct.
Jason Banks is offline   Reply With Quote
Old 07-21-2024, 12:48 PM   #12
Jason Banks
Here's a picture of a NOS Passenger side handle with the Key Parts Drivers Side Handle
Old 07-21-2024, 12:49 PM   #13
Jason Banks
Another View
Old 07-21-2024, 12:49 PM   #14
Jason Banks
One More
Old 07-21-2024, 12:50 PM   #15
Jason Banks
My Pictures make it hard to tell, but the screws on both go straight in. Not angled down like 68 and later.
Old 07-21-2024, 03:25 PM   #16
blazerowner71
Active Member
Thank you for the information I'm sure that will be helpful for others also
