Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-28-2023, 06:48 PM   #1
litebulblsc
litebulblsc's Avatar
Rear gear ratio question
I am considering a different gear ratio for my truck. Currently has 3.73:1. Playing with an online calculator, I could go down to 4.56:1 and still be able to get to 135 mph in 3rd. My fastest trap was about 118 mph, and I can only add so much more power with my current setup, that I do not see me hitting 135 mph in the quarter.
So is there a reason not to go with the lower gear ratio? It should make the truck faster, correct? The only down side I can think of is traction,but their are ways to overcome that.
litebulblsc is offline   Reply With Quote
Old 12-29-2023, 12:10 AM   #2
Getter-Done
Getter-Done's Avatar
Re: Rear gear ratio question
You could go with a 5:14.
The math is there.
84 Chevy K-20
Old 12-30-2023, 08:41 AM   #3
regan wilson
regan wilson's Avatar
A lot of things come into play on choosing the right gear. Tire size, transmission gear ratios, tq converter slip, max rpm etc.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 12-31-2023, 07:38 AM   #4
litebulblsc
The math is there.
I am aiming to up my mph some. That would put me at "redline" at the stripe with the convertor locked
Tire is 29.5
Trans ratio would be 1:1
I have a lockup convertor, so slip could be zero
Max RPM is 7000
With those numbers it comes out to about 135 mph at 7000 rpm.
Old 01-08-2024, 05:24 PM   #5
68racer
Yeah baby!
68racer's Avatar
I calculated that changing from 3.7 to 4.1 would give me a tenth or two. It made no difference at all, although it became more consistent. These trucks hit aero problems at the top end.
11.37 @116
68racer is offline   Reply With Quote
Old 01-08-2024, 06:38 PM   #6
regan wilson
I think 4.56 will work. Especially with the lockup converter.
Old 01-08-2024, 10:47 PM   #7
Ziegelsteinfaust
I run 4.88's daily with a Detroit locker in a 32" tire. Or a 285/65R17.
To me the biggest hold back of the combo is the TH700R4. If I had the money's to do over. A 4L80e would of been a more optimal choice.
Even though my engine is just a highly tuned gen2 LT1 it is a absolute blast to drive. I do miss the way bigger cam I had before. If I replace the cam it will be with a smog legal performance cam to get a little more out of her, but keep my drivibility.
My gear ratio, and Detroit effectively stop me from burning out. So that would be good for the 1/8 mile.
The same gear ratio hurts my top end charges a bit because my engine is more torquey vs 4500 rpm plus performance.
So with out mentioning engine specs or build list, and tire size.
Even 4.11's or 4.33's maybe a better split the difference overall combo.
Ziegelsteinfaust is offline   Reply With Quote
Old 01-09-2024, 01:28 PM   #8
litebulblsc
I ordered the 4.56s and a detroit locker last week. Can't wait till the Spring to try them out.
Old 07-16-2024, 07:49 PM   #9
litebulblsc
I can't get no tire traction. I can't get no tire traction. Cause I try and I try and I try and I try. I can't get no, I can't get no
That is the theme song of the truck now.
