Old 07-01-2024, 10:04 AM   #1
6600DURAMAX
6600DURAMAX's Avatar
Vintage AC and kicking on fans
Have a K5 blazer with a complete Vintage Air A/C kit installed.
Blazer has a LS3 with dual electric fans – fans run through the emc/pcm and are set to come on at 165 then kick off tcm speed has reached 30mph. My question is how do I wire my fans to kick on and stay on when the AC switch is activated?
There is no way in the pcm/ecm programming to do this.
Concern is overheating/ pressurizing the high side of the compressor when there is no airflow ( for instance upon startup or sitting in traffic ) before the fans activate
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 07-01-2024, 10:05 AM   #2
6600DURAMAX
Re: Vintage AC and kicking on fans
pic
Old 07-01-2024, 10:33 AM   #3
Sheepdip
Sheepdip's Avatar
Relay from your A/C "On" switch to your fans.
Sheepdip is offline   Reply With Quote
Old 07-01-2024, 10:37 AM   #4
6600DURAMAX
Even though I wired the entire vehicle I would say I'm amateur at best when it comes to wiring.
I have both fans on separate relays now and they tie into the PCM wiring
Could I splice into the same relays with the A/C on switch?
In my mind that would send signal to the relay just as the PCM would. just want to ensure it doest screw with the PCM
Old 07-01-2024, 10:57 AM   #5
Sheepdip
Sheepdip's Avatar
Without knowing your current wiring diagram that's a 50/50 shot. The trigger for your fans should (and that's the key word here) be a grounding wire.
Old 07-01-2024, 11:26 AM   #6
LNP
Did you check with Vintage Air to see if they can tell how to wire it up? For the PCM to activate the fans it would have to have a signal from the AC controls to the PCM so it knows you turned the AC on. If the PCM is out of a donor car look up the wiring diagram fpor that car and follow the wires for the AC to the PCM. As said before computer control cars use the ground as the signal not the positive.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 07-01-2024, 11:40 AM   #7
6600DURAMAX
Vintage Air recommends a Trinary switch vi the binary switch I currently have in place. This switch will sense when the pressure is above 250 psi in the condenser and turn on the fans.
Just ordered one !! Will let you know how it works
Old 07-01-2024, 01:05 PM   #8
LNP
Good to know hope it works for ya.
Harley
Old 07-01-2024, 02:19 PM   #9
A1971Blazer
A1971Blazer's Avatar
just addressed this on the LS1 swap in my '67 C10
you can't just wire the trinary to one of the PCM fan trigger grounds,
it will work but will set a P0480 or P0481 code depending on which fan it's connected to.
check this post for the solution.
I rewired mine this way and it works now without setting a code.
https://67-72chevytrucks.com/vboard/...d.php?t=853200
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 07-01-2024, 04:38 PM   #10
RustyPile
RustyPile's Avatar
I have 2 fans on the radiator. That's exactly how I have one of mine wired, and it works perfectly... The other fan is on a relay activated when the ignition is switched ON. A sensor in the radiator provides the ground path, and set to turn off if coolant in the radiator is below 165*...
RustyPile is offline   Reply With Quote
Old 07-02-2024, 06:00 PM   #11
Accelo
Accelo's Avatar
The bad news it you will have to drain and fill the system to install the Trinary switch.
I am surprised this isn't possible, my early LS1 computer has an "air is on grounding terminal" Every PCM system I have seen has an output for the scanner to read the status of the "AIR". I would look closer at the factory system for the grounding when AIR is active and the matching computer input from the AIR. I could be full of it, as I though the ECM for the LS3 used PWM for fan speeds. Some more research may be necessary.
Accelo is offline   Reply With Quote
Old 07-02-2024, 11:09 PM   #12
Richard
I pinned my PSI harness for the factory A/C pressure sensor. Am running the e67 ecu that came with the engine. I am also using a variable speed 850w PWM fan controlled by ecu. My research revealed that the ecu will automatically bring my fan up to 50% duty cycle when A/C pressure rises above the high threshold. Of course the ecu will adjust fan speed according to engine temp as well.
Richard
Old 07-16-2024, 03:16 PM   #13
6600DURAMAX
My tuner says that this ECM doesnt have a AC pin it was controlled by the BCM
Old 07-16-2024, 03:50 PM   #14
weq92f
weq92f's Avatar
My MSD Atomic EFI computer controls the fans based on temp settings. To get the A/C to trigger one of my fans, I ran a tap wire from the binary switch to the relay 12v trigger for the fan I wanted to kick on with A/C. Essentially I'm tapping into the compressor clutch 12v. Later, I did the same thing with a pusher fan placed on the condenser.
Since then I have installed a trinary switch for the purpose of having the supplemental pusher fan only kick when pressure limit is reached. Reminds me...I need to finish that up!
Hth,
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 07-16-2024, 10:56 PM   #15
Richard
This is true for the e67 ecu I am using. My understanding after much research is the fan control is separate from A/C control. Therefore if the pressure sensor is installed and the ecu sees the high pressure it will send appropriate fan signal to the fan1 wire (on/off or PWM signal). Ecu does not need an A/C command. Your tuner said it "A/C is controlled by the BCM"
Edit- Popped into my head. Maybe look at the pressure sensor signal to ecu as "A/C is on so turn on fan" I am using this to integrate the pressure sensor and high/low pressure switch. https://bp-automotive.com/product/ls...re-transducer/ The pigtails for the switches are available but not sold by BP. What ECU are you using? The great benefit of using this option over the A/C compressor lead is that the fan will only run when needed. Using the compressor lead or cycling switch will make fans run always when A/C is on. Fan is not needed at highway speed. Eliminates trinary switch and extra wiring.
Richard
