Old 07-13-2024, 11:48 PM   #1
lkt1954
Active Member
Alignment & Coil over adjustment
Getting close to the end of finishing the 70 C 10 and have a couple of questions:
Front end is new with tubular a arms and coil overs on the front and rear. No shims on the front end and aligned by sight. Before I measure and order new wheels I would like to get the front end aligned and the ride height set.
Is there any reason not to do either one of the to the truck?
The truck still need the hood, grille, seat, glass and bumpers.
Also I installed a 88-94 steering wheel and when tightened down, it still wobbly.
It's installed a a tilt column from flaming river. I simply installed the wheel and then tightened it down. Am I missing something here?
lkt1954 is offline   Reply With Quote
Old 07-14-2024, 03:03 AM   #2
RustyPile
RustyPile's Avatar
Re: Alignment & Coil over adjustment
Ride height is a big factor in the alignment. Camber changes as suspension moves up and down.. With that many "missing parts", the ride height will be higher than normal.
As for that wobbly steering wheel.. First thing that comes to mind is those aftermarket steering columns use GM components.. There is a spring under the T/S canceling cam that preloads the upper bearing.. If that spring is missing, the shaft will wobble... A question might be addressed to Flaming River: Is the 88 - 94 steering wheel compatible with that particular column??
RustyPile is offline   Reply With Quote
Old 07-14-2024, 03:28 PM   #3
theastronaut
theastronaut's Avatar
Wait to align it until it's all assembled and full weight, ideally with half a tank of gas and your weight in the driver seat to settle the ride height as close as it'll be to when you're driving it.
If it has new springs that need to settle, set the toe to 1/16" in yourself and put some miles on it to settle the ride height/springs before having it professionally aligned. Caster or camber misalignment won't wear the tires.
Good specs to shoot for since it's no longer stock and on bias plies-
-.5 to -1 camber
1/16" toe in
More caster than stock, hopefully the tubular arms allow for around 7 degrees. Slight stagger in L/R caster to compensate for road crown.
theastronaut is offline   Reply With Quote
Old 07-16-2024, 11:26 PM   #4
lkt1954
Active Member
Thanks for the advise, guess I'll wait till then.
Old 07-17-2024, 04:37 PM   #5
lkt1954
Active Member
Just got an answer from flaming river and OEM steering wheels cannot be used on their columns and they do not make an adaptor to make them work.
So I guess the steering wheel goes and I have to find one that works.
Anyone using an aftermarket steering wheel on a flaming river column?
Old 07-17-2024, 07:52 PM   #6
MySons68C20
MySons68C20's Avatar
I used these guys https://fssteeringwheels.com/
MySons68C20 is offline   Reply With Quote
Old 07-18-2024, 05:53 PM   #7
RustyPile
RustyPile's Avatar
I have a Lecarra wheel on mine.
https://lokar.com/lecarra.html
Old 07-19-2024, 11:47 PM   #8
lkt1954
Active Member
Thanks. I am going with the forever sharp steering wheel.
Talked to them and they need to know what upper shaft flaming river is using.
Just waiting for an answer from flaming river to move forward.
