07-06-2024, 11:24 AM | #1 |
Inner race turns in the hub on my k20
Put it here for more exposure. Repacking the front bearings they had plenty of grease but I’m going to Tennessee next week . Bearings all clean look pristine but when wiping out the old grease the inner race turns in the hub . Not sure if I should continue or get new cups and cones
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
07-06-2024, 12:01 PM | #2 |
Who Changed This?
Re: Inner race turns in the hub on my k20
That should be a press fit. Can you slide the race out of the hub? Given the tight tolerances on bearings, I'd think that the hub is damaged.
07-06-2024, 12:05 PM | #3 |
Born Psycho
the race is much harder material than the hub, if it spins you need a new hub. i have in the past used a center punch to score the hub so the race would be tight- but only in an emergency situation until i could get a new hub.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
07-06-2024, 12:17 PM | #4 |
All about them K’s
Yep exactly correct. I’d replace that hub and races at a minimum asap.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
07-06-2024, 12:21 PM | #5 |
Looks like I’ll be taking the 72 to Tennessee.
07-06-2024, 01:14 PM | #6 |
Ordered the complete rotor and hub assembly. Raybestos brand won’t be here till end of next week .
07-07-2024, 08:50 AM | #7 |
Popped out the race it’s been overheated. I have the hubs coming and I just ordered the cones and cups from Rockauto
07-07-2024, 10:13 AM | #8 |
Who Changed This?
Good thing you found that before you left on your trip!
07-07-2024, 10:17 AM | #9 |
All about them K’s
Good call, that’s probably been that way for a minute. Luckily you can still find the 44/10 bolt hubs fairly cheap/easily. It’s nice when you can get them assembled with the rotor like that. My front Dana 60 is expensive to replace hubs on and they are a little tougher to find.
07-07-2024, 11:24 AM | #10 | |
Would have sucked big time getting stuck
07-08-2024, 07:21 PM | #11 |
Well the hubs will be here tomorrow morning I’m going to try and get the cones and cups at Napa tomorrow. The online order site says that I can order tonight and pick up tomorrow. But I’ll just go to the store early and see if I can get them . I’ve had the order now and pick up tomorrow lie before .
07-08-2024, 09:54 PM | #12 |
Who Changed This?
If the cups in the new hub are the same brand, they should match the cones. I've seen where one can buy the cones only. I don't know if there is any savings with that, beyond the time of having to pound out the "old" ones and pound in the new ones. Working as a piece-work mechanic in the past, it would have been less labor.
07-09-2024, 08:48 AM | #13 | |
07-09-2024, 10:03 AM | #14 |
Locktite makes a green compound that works well for this application. I’ve had to use it for knuckle bearing races. I always knurl the edges of whatever the race is going into, apply green compound, then press the race in.
1970 GMC c15 LS swapped 1970 Chevy K20 350, 465, t221 1968 Chevy K20 400sbc, 465, t221 1968 Chevy K20 roller, to be continued… |
07-09-2024, 11:10 AM | #15 |
Not a fan of chemical bonds overheat it and it turns to goo . Granted the high temp is rated to 450 degrees but I’m not trusting it . I’d rather replace than patch .
07-09-2024, 11:21 AM | #16 |
All about them K’s
Glad you are getting back together, you definitely made the right call replacing the hub. As for the newer race in the old hub I wouldn’t put it past someone in the past to have just dropped a new race into a wore out hub. Lots can happen In 35-40 years.
07-09-2024, 01:13 PM | #17 |
I’m the third owner . Both prior owners were very anal about the truck . I have every receipt and work invoice and every piece of the original paperwork including the bill of sale . Guy even kept the recall notices and the envelopes they came in . First owner was a mechanic second owner is a member here .
07-09-2024, 02:25 PM | #18 |
Hubs came today . Races were pre installed so much nicer that the rotor was installed too
Today, 05:37 PM | #19 |
One done
Today, 09:39 PM | #20 |
Congratulations! Time to pour yourself a tall cool reward.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Today, 09:41 PM | #21 |
All about them K’s
Nice!
