Disc brake swap positive camber issue SOLVED
Hey guys, I recently did a disc brake swap on my '67 C20. Donor parts were from a '73-87 squarebody. After completion, I noticed positive camber without any shims. After Googling it, I saw that some members who did this swap also had the same issues. Here's what I found.
To start off, I wanted to keep the 67 as original as possible. So I used my original upper and lower control arms and front crossmember. These were in better shape anyway than the donor parts. The only parts from the donor I used were the idler arm attachment, drag link and spindles. After noticing the positive camber, I checked the upper and lower control arm measurements compared to the donor parts and they were the same. Where the difference lied was at the upper control arm attaching bracket. Drum brakes use a bracket that is a casting. Disc brakes use a bracket that is a stamping. The original casting has shoulders at each mounting stud that are quite large compared to the disc brake stamping. There are also pads on the frame side of the casting where it bolts to the frame. These, along with the shoulders around the studs add up to the positive camber problem when compared to the square body stamping.When I switched out the casting for the stamping, my problems were solved. Check photos.
John 1967 C20 2WD Longbed 2001 2500 HD 4X4 Extended cab long bed ![]() |
![]() Join Date: Feb 2016
Re: Disc brake swap positive camber issue SOLVED
Interesting bit of information that may save someone down the road some heartache. Thanks for posting your findings!
I'm not sure that the cast piece is a drum brake piece as my 67 Burban has the stamped style. It is a C10 from Fremont truck. I wonder if the cast ones are C20 or possibly pre-67 left overs that got used on early 67 trucks. Maybe one of the experts here will chime in and correct me.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Check post #10 here:
https://67-72chevytrucks.com/vboard/...0+camber+issue He has a 1/2 ton 1968 with similar issues. Looks like he has the casting with large shoulders like I do. Hmmmm...... makes me wonder.
I am so happy to see someone with the time and patience to dig all the way into this. Thank you for sorting this out. Now I guess I need to sort of the stamped brackets.
I will post on how it turns out. But I can definitely see a thickness difference. |
Spoke too soon. I have stamped brackets.
