Old Today, 02:11 AM   #1
harrisdaniel1022
New Member
52 Chevy step side frame swap
Hey, I am trying to figure out which frames my truck will fit on best. I found a 2006 Chevy Colorado, and am trying to figure out if the frame will fit. If the frame is too long I can cut it down, but If it is too wide I'd rather not deal with that
harrisdaniel1022 is offline   Reply With Quote
Old Today, 12:29 PM   #2
leegreen
Re: 52 Chevy step side frame swap
'52
Front tread 57 Inches
Rear tread 58-3/4 Inches
Wheelbase 115 Inches
Colorado looks like
Front track 59.6 in.
Rear track 57.5 in.
S10
front 2wd 55
rear 4wd 60
You will find tons of S10 swap information on the web, not so much the colorado. But I'd like to see a colorado frame swap project or two.
leegreen is offline   Reply With Quote
Old Today, 12:34 PM   #3
harrisdaniel1022
New Member
Yeah that's the issue I am running into, I like the Colorado option because of the upgraded suspension and brakes and all that stuff. I may just try it and if it doesn't work sell the parts and start over
Old Today, 01:04 PM   #4
leegreen
tape measures are cheap...some things I'd start with:
AD noses are short relative to newer stuff. On Colorado frame what is distance from front wheel center to furthest forward thing on the frame you can't cut off?
What is height & width of the strut towers vs AD fenders / hood?
is there room for motor and a radiator between where the AD sheet metal goes or do you have to move the entire engine package back?
Can you fit the motor you want to run into a colorado frame?
Can you reposition the steering to have the wheel closer to centerline of truck without major work?
Old Today, 01:21 PM   #5
harrisdaniel1022
New Member
Well one thing I was thinking about doing is cutting the firewall out and leaving the Colorado firewall so I don't have to change AC and brake booster and all that stuff can just stay where it is. Might have to trim the height or width
Old Today, 01:22 PM   #6
harrisdaniel1022
New Member
Also the Colorado I found for sale is a good distance away so I can't just run over and measure it
