Old Today, 04:07 AM   #9
popeyestruck
Re: throttle linkage hit exhaust bolts
Originally Posted by mr48chev View Post
I'm thinking that the rod is not supposed to have that bend in it. Both of them that are on cabs I have are straight in that area but one is bent from being banged around for the past 30 years that I have had that cab.
It has an auto choke carb on it so someone changed out the carb at one point. I think they just bent and cut things to make it fit. I'm going to try straightening it a little at a time until it clears then see if I have full throttle travel. I may need to cut a section out of the middle to shorten it when I straighten it it might make it too long.
popeyestruck is offline   Reply With Quote
