Old 07-21-2024, 09:22 AM   #1
jbgroby
jbgroby's Avatar
Need help on mounting door handles
Any of the members have a door handle templet and/or can explain a simple way to use it in the correct manner. I used mine and drilled two small guide holes in my panel (the handle will cover those holes), but I can see where they will not line up with the base nuts. I had to measure these wrong. Any help appre. I've either cut the templet wrong or started with a bad measure and it went downhill from that point.
jbgroby is offline   Reply With Quote
Old 07-21-2024, 10:21 AM   #2
bhap
bhap's Avatar
Re: Need help on mounting door handles
I had a similar experience installing the handle on the passenger side. I had an original template and lined it up the way I thought was correct, drilled and then found out the holes didn't line up. What I did was put a couple of bolts through the captive nuts from the backside and let them protrude slightly towards the door panel. A dab of grease on the ends of the bolts and then installed the door panel with a couple of the top screws. This gave me a couple of grease marks on the inside of the panel as a guide for drilling the holes. Hope this helps!
bhap is offline   Reply With Quote
Old 07-22-2024, 06:35 AM   #3
jbgroby
jbgroby's Avatar
BHAP,
Yes, I'll do that, I've used that method before with sheetrock and an electrical box, only with lip stick. I forgot, THANKS!!!
Old 07-22-2024, 03:52 PM   #4
forestb
forestb's Avatar
Make sure your holes are big enough. The bolts come in at quite an angle so the holes need to be bigger than you might think. I remember thinking that the template was telling me to drill big holes and I thought, I know better than they do, and drilled a smaller hole and then could not bolt it down.
forestb is offline   Reply With Quote
