Bracket for drive shaft carrier bearing
The previous owner welded the carrier bearing to the bracket that it bolts to and there no longer seem to be any bolt holes for the carrier bearing to attach to even if I was able to cut off the bearing. Does anyone know if there is a replacement bracket that can bolt on where the current bracket is?
Re: Bracket for drive shaft carrier bearing
It sounds like you’re going to need a new cross member.
At the very least, you need to fabricate the mount point. It needs to all be lined up as it was from the factory, or you’ll forever have driveshaft issues |
#3 | |
![]() Join Date: Feb 2009
Look on the parts board, though you have to be a paying member to do that.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; Yesterday at 10:31 AM. |
#4 | |
The Older Generation
He doesn't have to be a paying member to look, or buy items posted for sale on the parts board. He would have to be a paying member to post a want to buy though, I think that is what you were thinking about.... .
![]() Join Date: Dec 1999
Post some pictures of what you are working with. Maybe we can point you to exactly what you need...
#6 | |
Probably, thanks
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Born Psycho
![]() Join Date: Feb 2001
if you can post a picture of your bracket someone on here can help i'm sure.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Long or short bed?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
That's what I was afraid of
Since you are new here, to post a picture, click the "Go Advanced" button underneath the "Quick Reply" section "Message" box where you would normally type your reply in this thread.
Once on the advanced page there is a Paper Clip icon where you can attach files. |
