Old 07-22-2024, 08:06 PM   #1
Robert Crandall
Repair Manual Question - Engine Torque Values
I work from a 1977 Chevrolet Light Duty Repair Manual. Every section shows a page for Specifications. These pages give torque values.
I cannot find torque values for the engine section. A page for Specifications are not shown in any of the 3 indexes (main, 6cyl, 8cyl). The last page of the engine section is Specifications for engine measurements, but no torque values are shown.
I am certain that it is reader error on my part, but can anyone guide me to where the torque values for engines are shown?
Thanks!
Robert Crandall is offline   Reply With Quote
Old 07-23-2024, 10:08 AM   #2
geezer#99
geezer#99's Avatar
Re: Repair Manual Question - Engine Torque Values
Like this.
From my 1976 motors manual.
Sorry about it being sideways.
geezer#99 is online now   Reply With Quote
Old 07-23-2024, 10:58 AM   #3
Robert Crandall
Thank you for your help. I find it hard to read, and I am not at first able to print it in a form that I can read, but I will work on that.
Again, thanks!
Old 07-23-2024, 11:09 AM   #4
geezer#99
geezer#99's Avatar
Try again
Old 07-23-2024, 01:46 PM   #5
Robert Crandall
Thank you! That copy is readable, and the print screen is also. I added the page to my book.
I am tightening valve cover and oil pan bolts. I found somewhere on this forum 80 inch lbs for the 1/4 inch bolts and 165 inch lbs for the 5/16 inch bolts. I wanted to see what the book showed, but I cannot find those values in my book. I could not make myself get them that tight, so I chose 50 and 75. Those values are far tighter than I have ever gotten them.
So far, the puddling seems to have stopped.
Old 07-23-2024, 01:53 PM   #6
geezer#99
geezer#99's Avatar
I’ve always gone by feel. Never got lucky trying to torque them.
What type of gasket?
Cork, cork/rubber, rubber etc are different kinds.
Old 07-23-2024, 05:04 PM   #7
Robert Crandall
Cork. I always used to do the same. I never wanted to take a chance of mashing the gaskets or de-forming the sheet metal flanges, so I believe I was too easy on the tightening. I always had leaks. Now they are a lot tighter than I ever put them. I used the torque wrench to make sure that I tightened each one the same.
Old 07-24-2024, 10:55 AM   #8
MJN
MJN's Avatar
Here is the spec page from the 1976 truck service manual, http://www.73-87chevytrucks.com/tech...Supplement.pdf
I did look at the 1977 manual and it is strange there is no mechanical torque specs for the engine listed. Either way, hope this helps.
I would be sure to read the specs posted above closely- showing 50 FT LBS for rocker arm cover bolts- those little 1/4-20 bolts would never survive that or a cork gasket. I see the little note next to the torque value but cannot read what it refers to.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 07-26-2024, 07:23 PM   #9
Robert Crandall
Thank you very much for this and also for the link. I printed the page for my book.
I found somewhere on this forum 80 in lb for the 1/4 inch bolts and 165 inch lb for the 5/16. This new page shows the same 80 in lb for the 1/4 inch, but shows 75 in lb for the 5/16. Less than the 1/4 for the 5/16 does not seem logical.
I chose 50 for the 1/4 and 75 for the 5/16.
Old 07-29-2024, 09:35 AM   #10
MJN
MJN's Avatar
Its not all about the fastener size, take into account the gasket material and where on the engine its used as well. The timing cover uses a paper gasket where rocker covers or oil pan used cork gaskets. The cork gaskets would have a lesser torque value to avoid crushing the gasket even with a 5/16 fastener.
'17 GMC Yukon XL
VCCA member #58596
Old 07-30-2024, 11:12 PM   #11
Robert Crandall
Thank you for your clarification of this. Lucky for me, the 50 that I chose for the main oil pan bolts does not exceed the specification, and the 75 that I chose for the end bolts match what is required.
