Old 06-19-2024, 10:31 PM   #526
hewittca
hewittca's Avatar
Re: My 1967 Build (Finally)
Awesome updates lately! Congrats on making that first drive. The truck looks great.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 07-12-2024, 10:36 AM   #527
KyleSeal
KyleSeal's Avatar
It always amazes me how something can look reasonably straight, but as soon as you put primer and 80 grit together it shows a whole other side to it. Now I am not a fan of over filling, actually I am a victim of bondo (lol), so I am careful when I tackle body damage. Given I cant get to the back side, I used a dent puller and got any spots about 90% there. Then some filling and a good bit of priming.
I also did the seam sealer while I was there, which I will say is a HUGE pain. Really wish there was (or that I bought) some stuff that sets off later. Thats a lot of surface area to cover in 10 minutes. But its done, I did some high build to get it nice and level for a base, then some medium flow and then high flow. Really wanted it to look well done, and it came out pretty good Id say.
Size:  55.6 KB Name:  IMG_8560.jpg
Size:  30.4 KB Name:  IMG_8582.jpg
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is online now   Reply With Quote
Old 07-12-2024, 10:45 AM   #528
KyleSeal
KyleSeal's Avatar
Ordered some of the ACC floor mats from RockAuto, and they fit very well, pretty well tailored to be honest.
Came across a strange leak, at first I thought my welds on the valve cover were leaking oil past them, but it is actually the pushrod and rocker tossing oil into the breather, and running out when I am under harder acceleration. Glad I just rattle canned these covers instead of powdercoating them first, Ill add a splash shield welded in place in there to deflect the oil stream. Just the woes of a fresh full build!
Installed the rear window for the time being so I can take the truck to shows and not suffocate from exhaust coming in the back window. But I do have to say, I miss that breeze lol.
Size:  77.9 KB Name:  IMG_8777.jpg
Size:  83.1 KB Name:  IMG_8683.jpg
Old 07-12-2024, 10:55 AM   #529
KyleSeal
KyleSeal's Avatar
Back on the street! So much fun to drive. Need to adjust the rear arms to center the wheel, and need to probably remove the inner fenders on the front, I rub a good bit.
Ordered some QA1 single adjustables as well, the KYBs on the truck are OK but would like to adjust it some to make the truck a bit more fun, also to help adjust for when I have a bit of weight in the bed for swap meets (so its not too bouncy).
Also going to add a posi to the list of wants, I didnt care much for dual wheel peel when I was building the truck, but this truck does have a lot more power than I anticipated
Old 07-12-2024, 11:17 AM   #530
Shifty One
Shifty One's Avatar
Good to see you enjoying that baby, even if it does need a few tweaks here and there....whose doesn't/didn't?
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 07-12-2024, 12:40 PM   #531
KyleSeal
KyleSeal's Avatar
Absolutely. Its nice to have a vehicle that is now running, makes you really want to fine tune it. I probably should have moved the battery and modified the fenders earlier, but hindsight is 20/20 right lol. Soon Ill have a shop do a full laptop tune, once I work every little bug out of it.
Old 07-12-2024, 12:47 PM   #532
KyleSeal
KyleSeal's Avatar
It was a great feeling. So many years of dreams all converging on one day. And to top it all off, the stereo works!
Old 07-12-2024, 12:48 PM   #533
KyleSeal
KyleSeal's Avatar
Some photos of the truck. A few taken by some friends at local shows, and an interior shot during the day. Really need to do a decent photoshoot around sunset but honestly I am having too much fun driving it to stop and take photos
Old 07-12-2024, 12:51 PM   #534
loudchevy
loudchevy's Avatar
Roof is looking great. Nice job on the drip rail sealer!
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is online now   Reply With Quote
Old 07-12-2024, 10:32 PM   #535
Getter-Done
Getter-Done's Avatar
Attachment 2378247 Attachment 2378248
Attachment 2378249 Attachment 2378250
Attachment 2378251
That looks better than any one that came out from the factory.
That just MHO. Great work.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 07-15-2024, 08:27 AM   #536
KyleSeal
KyleSeal's Avatar
Thanks yall! Im very happy with how its coming out, cant wait to get actual paint on it, just too hot here to really mess with it let alone paint. Soon as this weather calms down it will be back into the booth and get some real paint on it! (the roof only that is)
Old 07-15-2024, 08:34 AM   #537
KyleSeal
KyleSeal's Avatar
Added some QA1 single adjustables, part number TS405 & TS504, and they are great. Really nice to have the ability to adjust on the fly and really dial it in.
Would you believe me if I said I feel better throttle response? Lol. It really doesnt feel like it squats too harsh under heavy throttle, it just gets to going.
One thing I did need to do was space the lower one out from the mount, as the body was contacting some. I will make a spacer for this eventually, but some thick grade 8 washers did the trick for the weekend.
I do also need to address the front suspension / inner wheel wells. If I really watch it, I wont hit, but any ripple in the road makes me contact the inner fender well in the front. Which is super weird, because I did a dry run with no spring and a jack, tucked the wheel all the way up and never rubbed. Oh well, I just need to get the liner out and find some way to move it up. Hate the idea of running with no fender well, but this was the life I chose!
Size:  57.0 KB Name:  IMG_8863.jpg
Old 07-15-2024, 10:06 AM   #538
KyleSeal
KyleSeal's Avatar
Some better shots to show off the stance of the truck. And the obligatory dealership shot.
Size:  89.5 KB Name:  IMG_8843.jpg
Size:  87.4 KB Name:  IMG_8848.jpg
Old 07-15-2024, 11:09 AM   #539
Shifty One
Shifty One's Avatar
That is really nice Kyle! Cheers!
Old Today, 06:54 AM   #540
hewittca
hewittca's Avatar
Your truck turned out really nice. I'm curious to see what you do with the inner fenders because I also need a solution and have no good ideas.
I'm trying to figure out what's on your windshield in the last few pics.
Old Today, 08:06 AM   #541
KyleSeal
KyleSeal's Avatar
Mechanical oil pressure gauge, the electric one offers no measurement other than high or low, so I wanted to see what the exact numbers were. Its been 98*+ here for a while so I was trying to find an oil weight that got me a swing of 20-60psi when at 195* coolant temp
Old Today, 10:18 AM   #542
loudchevy
loudchevy's Avatar
Now that makes sense, I was wonder what that was on the windshield as well.
Scott
2003 Tahoe Stock
Old Today, 10:58 AM   #543
KyleSeal
KyleSeal's Avatar
Both my Chevys have had gauges taped to the windshield recently the 67 has the oil pressure gauge and the 54 Bel Air has a fuel pressure gauge (intermittent loss of fuel pressure)
1967, custom, dropped, lowered
