#101 |
Re: 1970 C10 ChassisFab Build Thread
Nice job on the tubs. Did you have to get extra tubs for your filler piece? When I did mine I used scrap that I cut out of my inner bed sides when I raised the floor. I still need to finish welding my tubs, it's been over a year!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
#102 |
That's super clever I hadn't even considered that! I did buy two tubs for each side... I wish they still made CHUB TUBz in the stock wheel width
My 1970 C10 ChassisFab LWB to SWB Build Thread |
#103 |
Fitting some pieces for the raised fiberglass inner fenders
#104 |
![]() Join Date: Aug 2004
Nice clamp usage! Those pieces aren’t going anywhere
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#105 |
New tailgate fits alright! Working on the bed floor, rear tubs, and tailgate filler panel.
#106 |
![]() Join Date: Oct 2012
Where did you get the tailgate from?
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#107 |
LMC for nearly all of my parts
#108 |
How did it line up with the bed sides? I need a tailgate, not sure if I want to go the LMC cheaper route or pony up and buy an OG old metal tailgate.
#109 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Shes coming along...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#110 |
I can't complain with this one from LMC. I used the stock hinges and handle with it to make it feel more "solid" like the original
#111 |
Trying something different with the tailgate filler panel. This is an inner tailgate skin. It's gonna take a fair amount of fit and finish back here, along with installing the emergency shrader valves and remote battery posts.
#112 |
Is that panel left over from the original tailgate? If so great re-use of material.
#113 |
![]() Join Date: Mar 2011
WOW factor..... great Idea !
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#114 | |
I might trim off the dented part near the bottom or tack some new sheet metal right there.
