#26 |
Re: IMPOSTER! ( or hey guys I got a little jimmy!)
While I was at the salvage, I was geekin out about some of the stuff they had. A 65 Mustang, a 50s Mercedes, and this ultra cool International with aftermarket tool box fenders on the step side bed. Those would be cool on a Delmo style build.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
#27 |
This is the seat pattern I want to copy, just in a different color scheme. I've had this photo in my pc for years and years, I'm not even sure where it came from anymore.
#28 |
Working on building a bed wall / cubby hole behind the seat. Could be a great place for the battery or subwoofers or who knows what. Also got one back inner fender notched around the tire and putting the tub back in. I had bad luck trying to make the 1.5” wide splice to fill the gap when I moved the tub in. I couldn’t get the bead line correct at all with the tools and skills I have. I looked and found Summit had a rear tub by AMD for $60. Sold! I trimmed it to fit all the way to the bed, cut the excess part off the bed wall, and started fitting the tub. The part I cut off I can use to patch the other side, although I almost want to get another cheap tub from Summit. Much much faster.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 Last edited by OKGMC4; 04-11-2024 at 05:08 AM. |
#29 |
Splicing the other tub in.
#30 |
Just hammer and dolly work now.
#31 |
![]() Join Date: Jun 2002
Nice! Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
#32 |
![]() Join Date: Apr 2008
You’re good at fabricating!
71 C10 72 K20 72 K10 Super Kirk |
#33 |
Awesome work! I am in!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#34 |
Thanks for the kind words!
The dash will be body color, but not the door panels. In an effort to have the door meet the dash and flow together better, I used some 5/16 rod and some sheet metal to rework the lines.
#35 |
Awesome.
"If I had your hands I would cut my hands off" |
#36 |
Been waiting 16 weeks for the drop member. Looks awesome! Have not even had a chance to get in the garage for 2 months. Online classes and work and grandkids. I’ll get there though. Got tired of fighting the stock crossmember, specifically steering. Could not make a Dakota rack work, and the Porterbuilt stuff should get me back on track.
#37 |
@OKGMC4
Tha's gonna be a sick ride. I am definitely down for the ride, subscribed. |
#38 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Sweet build i fought the front crossmember as well and finally ordered the p.b. set up...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#39 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Nice metal work! I'm subbing to watch...
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
