Old 07-28-2024, 11:07 PM   #1
dooguy
turbo 400 kickdown switch
anyone have some info on how to adjust this switch on a 72 gas pedal mount
dooguy is offline   Reply With Quote
Old 07-28-2024, 11:58 PM   #2
kwmech
Re: turbo 400 kickdown switch
The mount has different holes in it for the switch. Finer adjustment in the past I have put a piece of hose around the tip that sticks out
kwmech is online now   Reply With Quote
Old 07-29-2024, 12:29 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I will look at the one I have in the morning and take a couple of pictures of it to see if there is anything different on it.
Leon
Old 07-29-2024, 01:10 AM   #4
dooguy
i am not seeing any adjustment in the mount. switch can only fit in one position. I have seen different posts that say you need to reset switch and then depress accelerator to self position, but i have had no luck trying the suggested reset methods.
I'm thinking like you said putting something over tab that sticks out
Old 07-29-2024, 09:19 AM   #5
LockDoc
LockDoc's Avatar
Here is the one I have. I see no adjustment in the bracket or switch. There are three holes in the bracket, two of them are for locator tabs on the switch and one is for the screw.
The instructions for adjustment you are reading are for the TH350 kickdown CABLE. I don't know if any of the 400's use that system or not. That adjustment will not work for the electric switch.
Leon
Old 07-29-2024, 10:20 AM   #6
Accelo
Accelo's Avatar
The switch is self-adjusting.
There is a locking tab on the switch which can be moved by finger pressure-- it's on the rectangular beige plastic part right against the steel. Just a silly little spring tab. Start with the pedal in the idle position. The switch won't be contacting the metal of the gas pedal assembly. Push in the tab on the switch, and "force" the movable part toward the pedal--you'll hear the ratchet/clicking noise. Then allow the switch to come back to it's normal position, so that spring tab pops out again. THEN move the throttle to wide ope, this sets the adjustment. There should be no need for rubber tubing on the gas pedal if the switch is adjusted properly.
I was designed so it could be installed at the factory and the first time the vehicle was floored it was set/adjusted.
Cheers
Accelo is offline   Reply With Quote
Old 07-29-2024, 11:45 AM   #7
LockDoc
LockDoc's Avatar
Cheers
I will check mine and take a picture when I go back out. (after lunch)
I didn't know about that. Thanks.
Leon
Old 07-29-2024, 03:24 PM   #8
dooguy
Cheers
i will pull my off again and see if I can figure it out
Old 07-29-2024, 03:56 PM   #9
LockDoc
LockDoc's Avatar
The only thing I can see are these tabs. Is that what you are referring to?
Leon
Old 07-29-2024, 05:06 PM   #10
dooguy
I have same switch as lockdoc. I'm having no luck pushing the tabs lockdoc is pointing and pushing moveable part of switch. I must be missing something or maybe switch bad?
Old 07-29-2024, 09:42 PM   #11
LockDoc
LockDoc's Avatar
I didn't try pushing on mine. I can do that in the morning. Maybe it has something to do with the 2 black slots on the side, I don't know.
Leon
Old 07-30-2024, 02:58 PM   #12
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Curious too. My 402 has the electric switch like above or close, with plastic lever. I'd be happy to see it more sensitive. Its due the 500 mile check up the rebuilt 400th, and I'll ask
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-01-2024, 11:38 AM   #13
kwmech
I see absolutely nothing on both of my trucks and even have a new one in a box. What is this April 1st? Unless there is something going down through the hole in the big pin to trip or lock
Old 08-01-2024, 11:48 AM   #14
pjmoreland
pjmoreland's Avatar
The photos above show the post that the pedal arm hits sitting approximately in the middle of the slot. What happens if you forcibly push on the post in the direction of the pedal arm? Will it scoot and stay?
pjmoreland is online now   Reply With Quote
Old 08-01-2024, 12:03 PM   #15
kwmech
nope, just pushes back and forth--- spring loaded. I think somebody is pranking us. Been working on these trucks for 50 years along with automatic transmissions and never heard anything about this
Old 08-01-2024, 12:19 PM   #16
71CHEVYSHORTBED402
Interesting, I found my original one like this. It's a plastic wrap of sorts. Next to that is a new one.
Old 08-01-2024, 12:29 PM   #17
pjmoreland
pjmoreland's Avatar
I knew I had one of these switches, but it took me forever to find it. It was in the first box I checked, but it was hiding under something so I missed it the first time.
If you push it forcibly in the direction opposite the spring, it pops out. Then, if you push the gas pedal to the floor, the pedal rod will set the switch to the correct position. I can hear and feel something ratcheting inside the switch when I reset it by hand.
Old 08-01-2024, 02:47 PM   #18
pjmoreland
pjmoreland's Avatar
I created a video that shows the adjustment procedure:
TH400 Kickdown Switch Adjustment Video
Old 08-01-2024, 03:15 PM   #19
71CHEVYSHORTBED402
How cool is that? Thanks for the demo. Unless I'm missing something, seems that's how it's set; adjustment is perhaps a misleading term. That is, I don't know, unless a guy can force the spot a pinch, I'd have to look unless someone already has that answer. It's not in front of me, access to my truck a PIA, but at least it's shielded well.
I can say mine can use a boost, and why some tape or something is an easy fix, described above. I'm going to pull my old switch, grab the vintage plastic piece adding depth to trigger faster.
If memory serves me right, the switch installs one way. Edit, perhaps not, after looking at some notes, "The switch bracket’s tabs insert into the accelerator bracket’s RH holes." That may be for simple positioning, now I really should look.
Edit 2, my notes were off kilter. Should read, "The switch’s tabs insert into its bracket’s holes from the RH side.".................... More importantly, my switch, bracket and accelerator assm. say they install one way.
Edit 3 I put one sleeve of quality electrical tape around the lever, followed by a sleeve of shrink wrap. No I didn't shrink it. I won't swear to a difference, but can say it kicked down as I expected it to, satisfied. Darn it, I threw the plastic spring wrap from my old switch away. Why, why, why? I suspect that's OE, but I know it's vintage. Not the first I chucked a part that's at or near impossible to replace.
I believe the switch part numbers are #1242101 and #7506100. The former leads to all kinds of passenger vehicles; but as trucks go, only 71-72 with 400TH.
Here's one installed.
Great education on a 71-72 400TH switch, thank you. Once again I see another reason to LOVE vintage. Vacuum and simple mechanical. I remain blown away by the cold start system, very cool stuff. I need to learn how to check/adjust a divorce choke though, that's becoming a lost "art", though it's probably so easy once done, like the rest on these trucks. Lost my buddy who set it for me. He set me up with the parts, and rebuilt the carb too. I learned of his passing the day I had to put my shepherd down, "can't wait to see Dana for my 500 mile check", "no you won't". He really liked my truck, and I loved him, we go WAY back to when I was a boy. I was looking forward to he seeing what we finished. Chalk that up near the top for least favorite days.
Old 08-01-2024, 11:26 PM   #20
dooguy
thanks for the video. My existing switch would not adjust like that. I have another on order, hope it behaves like your post
Old 08-08-2024, 07:20 PM   #21
dooguy
Received new switch today. Still doesn’t adjust as shown in video
Old 08-08-2024, 07:32 PM   #22
pjmoreland
pjmoreland's Avatar
Send me a PM with your address, and I'll send you mine. I don't need it.
