Old 07-27-2024, 01:22 PM   #1
JDarby
Active Member
Vacuumn wiper replacement?
I had purchased a 2 speed electric wiper kit off of eBay and then waited to long to test it , passed my return window.
Now that the AC unit is in place I realize the one off eBay will not work for me.
Have any of you tried the units' sold by LMC Trucks?
They look like a direct replacement.
Im not opposed to using RainX and leave the vacuum ones in place!
Thanks for your time!
1955.1 GMC 100 RestOMod
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
JDarby is offline   Reply With Quote
Old 07-27-2024, 05:37 PM   #2
nvrdone
Re: Vacuumn wiper replacement?
I went with a major well rated electric wiper kit. What a pain to install. First the mounting bracket didnt fit the truck. Then trying to install the switch in the dash, It wouldnt clear the motor. I had to make up a 1/4" spacer to lower the motor so it wouldnt hit the switch. Finally removed the old throttle cable knob and mounted the switch there. Once I got it all installed the wipers only clear about 1/3 rd of the glass. If I set the self park to be parallel with the bottom of the glass the wiper only goes up so it is sitting straight up. Fortunatly where I live we dont need wipers and if we do I just dont drive the truck.
If I were to do it again I think I would use the original vacuum wipers with a seperate vacuum pump to power them.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is offline   Reply With Quote
Old 07-27-2024, 06:08 PM   #3
vintovka
vintovka's Avatar
Went with electric -- hate it. If i still had the ability and the parts i would have added a aux 12 v vacuum pump and run an original motor off it. Had i been thinking it would be a no brainer to run the pump to the power brake cannister as a reservoir. If anyone likes this idea i have a near new 12 pump from Jegs sitting here cheep. Really miss the sound of the old vacuum wipers as well.
vintovka is offline   Reply With Quote
Old 07-27-2024, 07:56 PM   #4
JDarby
Active Member
Thank you guy's this is very helpful!!
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
Old 07-29-2024, 12:59 PM   #5
Thadious
I had designed a 12v system years ago when I did my first build. The information is still there if you want to see what I designed. I found my drawings not that long ago and just picked up a CNC machine to rebuild in the future and have considered making kits again but I would need to source what the materials would cost these days. May be cheaper in the end, but I've heard a fair bit of issues with the other aftermarket setup, not to mention that they are pretty expensive!
https://67-72chevytrucks.com/vboard/...version&page=4
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old Today, 03:16 AM   #6
mr48chev
mr48chev's Avatar
The Newport engineering unit that isn't exactly inexpensive is considered by most to be the best unit to use. Not a Universal fit but designed as a bolt in for specific vehicles
https://newportwipers.com/product/19...k/#wiper-motor
I've got a Specialty power windows kit for my 48 and most likely will use it as it is already paid for Bought before the Newport Engineering kits showed up and as I am not running a stock dash probably the best option for me although I would not recommend this unit WWK-4754-21 simply because I now believe that the newport kit is a better way to go. My kit is actually one step up from this one. https://www.ebay.com/itm/19563116905...0aAs3YEALw_wcB
My ongoing truck projects:
