02-05-2024, 03:15 PM | #1 |
SM 465 gear oil help
Looking to replace the gear oil in my 4 speed 68 but I’ve been reading not to use gl5, only 4, but it seems difficult to locate.
Hoping I can get some guidance on what to use Thanks |
02-05-2024, 06:14 PM | #2 |
Re: SM 465 gear oil help
02-05-2024, 06:55 PM | #3 |
Yep Lucas oil has it
02-05-2024, 07:11 PM | #4 |
The Lucas I’ve seen is gl5 rated and in my research it seems it’s had some issues with my type of transmission and the softer metals….
Is this a valid concern, or am I maybe reading too much into it and Gl5 products will work just fine? |
02-05-2024, 07:18 PM | #5 |
Was thinking of giving this a shot.
02-05-2024, 07:30 PM | #6 |
Sta-lube
NAPA carries it
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
02-05-2024, 07:45 PM | #7 |
Tried looking for that sta-lube but seems to be on back order at a lot of places, including my Napa and online
02-05-2024, 07:49 PM | #8 |
Crap I misspoke. I purchased VP racing GL4 not Lucas. Here is the link.
https://vpracingfuels.com/product/vp...80w-90/?c=394& |
02-05-2024, 07:54 PM | #9 |
GL5 is better than GL4 for gears in the rear end, but GL5 is bad for the brass syncros in the manual transmission. That doesn't mean GL-4/5.
Look for Sta-Lube GL-4 or Valvoline GL-4. Those are the ones I am usually able to find.
'67 GMC 2500, 292, 4spd, AC |
02-05-2024, 08:38 PM | #10 |
Didn’t see it was on back order why not use Valvoline 80-90 it’s GL 4 my local Autozone has it in stock for pickup today @ 33.99 a gallon
02-05-2024, 08:49 PM | #11 |
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-05-2024, 09:06 PM | #12 |
Thanks everyone
02-05-2024, 09:07 PM | #13 |
From Valvolines website says it for non synchronized transmissions
https://shop.valvolineglobal.com/pro...oil-sae-80w-90
02-05-2024, 09:13 PM | #14 |
Clear as mud CRC /Stay-lubes site
02-05-2024, 09:33 PM | #15 |
Anyone see any red flags with the triax I ordered on Amazon? Can always return and get something else.
GL4 and seems to be for synchronized… https://www.amazon.com/Synthetic-Shi...ws_feature_div |
02-05-2024, 10:48 PM | #16 |
I am not familiar with what you choose. A little late to the party. I ran a Jerico dog box in a road race application about 12 years. Refreshed every 2 years and oil changed at about 3 to 5 hours use.. Should have been more often but $$ always an issue. I experimented with 4 different oils. All 75-90. Thicker will affect you shift speed and ease of engagement, very critical for my use. Royal Purple was black. I did not like the results and feel it is a marketing product over real world result. Red line has a product that claims it fights gear crash. I bit, given critical for dog ring syncos It was ****. Mobil One performed quite well and price is decent. Hands down the oil that performed the best was Valvoline. It comes out as gold as it goes in. I use 75-140 in the diff. I do not have a cooler on the diff. It is a clutch style with ramps for the spider gears to walk on and tighten as torque is applied. Great for loosening in a corner, slipping the 5 clutches and then tightening down on corner exit. This allowed rotation in the corner and lock the differential on excelleration down the straight away. Lots of heat. The Valvoline 75-140 would pour in gold and out nearly the same color. I ripped a bunch of teeth off, and twisted splines but never a oil or heat failure. So Valvoline is my go to brand in all 4 of my cars and truck.
02-05-2024, 11:33 PM | #17 |
My brother sent me a link to this Site Years ago.
This has lots of Information/Opinions about oil. You have to Weed thru it though. Link: https://bobistheoilguy.com/forums/ Also this link: https://www.tractorbynet.com/forums/...shings.145754/ The 90 weight oil was safe for Bronze and (Yellow metals) years ago when these trucks was in there 20's. This new oil. Can you go Wrong with Syntetic or GL -12345? If you keep these transmissions filled with some oil that, Doesnt leak out faster that you fill it they will be okay.
02-06-2024, 10:14 AM | #18 |
If you haven't made up your mind yet Amsoil offers 75W90 for manual transmissions, meets GL-4 rating and protects brass synchros. Its what I run in my 4-speeds too.
https://www.amsoil.com/p/amsoil-75w-...gear-lube-mtg/
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
02-06-2024, 11:13 AM | #19 | |
Though I have 3 or 4 gallons of Sta-Lube GL4 on my shelf, If I did not, and with it being such a hassle to get GL4... I would just go with GL5 and be done with it. My two cents. Good luck! j
White K20 |
02-06-2024, 04:20 PM | #20 |
Nobody has stated if they see any red flags with the one I bought, so I’m gonna be the test dummy and report back.
I appreciate all of the other info and recommendations. |
02-06-2024, 04:36 PM | #21 |
All about them K’s
I run GL5 in mine and have never had a problem.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
02-07-2024, 05:47 PM | #22 |
The issue with GL-5 is that many GL-5 products have sulphur in them. The sulphur is to protect hypoid ring and pinion gears from scuffing wear, just as motor oil back in the day had sulphur in it to protect flat tappet lifters and camshafts. Same kind of wear. Sulphur however is corrosive to brass and other non-ferrous metals commonly used in some manual transmission synchonizers. That's why most manual transmission specified GL-4 because GL-4 does not have sulpher in it.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. Last edited by Bob B.; 02-07-2024 at 05:58 PM. |
02-08-2024, 01:21 AM | #23 | |
I have been using Lucas Full Synthetic Gear Oil in all of my rear ends and manual transmissions practically since it came out with never a hint of a problem, superb performance. Common to all synthetics that claim no posi additives required... I will call B.S. on that in my personal experience, I always add a tube and I have found the MOPAR to be the best. |
07-31-2024, 09:52 PM | #24 |
Just circling back to say the on I posted and bought has been working great!
07-31-2024, 10:19 PM | #25 |
Response of Results is Always a Good Thing.
