Help identifying my transmission
This one has me stumped big time.
The transmission that came in my '67 appears to be a TH350. HOWEVER, it has only two speeds. The trans pan has the angled corner notch and 13 bolts indicating that it's a TH350 which is a three speed. Thought maybe it a TH250 but that's also a three speed from what I found. I may at a loss as to what it is. Any help in identifying it would be greatly appreciated.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Help identifying my transmission
Defective TH350 that fails to engage one of its three gear ratios?
Is there a transmission listed on the SPID?
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Powerglide- 2 speed auto
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
![]() Join Date: Dec 2009
Here's a link with info.
Sounds like there issue with the transmission not shifting. Link: https://www.chevyhardcore.com/tech-s...uminum%20units
I went under the truck and shifted it manual and it is indeed a two speed. I went back underneath it looking for any markings on the transmission case. The only thing I found was 8T. There was no M33, M38 or M39 on it. Snapped a couple pictures hoping that would help.
Also, the guy I bought the truck from just had the transmission rebuilt.
20' Daredevil (Ret)
I was not aware that a Powerglide was still used in some of these trucks. Does a Powerglide have the angled corner on the pan? Seems like I learn a bit more almost every day -- or learn how much I don't know.
Peanut, if you can talk with the shop that rebuilt the trans, they should be able to fill you in on all the details.
Maybe the guy that rebuilt it done a custom job.?
How long is that tailshaft? That appears to be the T350 case. There was a long and short tail shaft on the T350. There was also a 12" tail shaft on some T350 cars. The aluminum case powerglide had 14 bolts in the pan. The Early Powerglide was Cast iron and IIRC it did not have a pan.
Look at the pans, they are different.
Who Changed This?
![]() Join Date: Jan 2013
Sure looks like a 350 pan. How many notches in the detents of the shift selector? Six (PRND2L) would mean a three forward speeds (THM) and five (PRNDL) would mean two forward speeds (PG).
In the two gears, how fast do you go at what RPM? As an afterthought, does it shift on time? If the vacuum modulator is weak it can shift way late or not at all, and you might not be getting high gear.
