Old 01-11-2019, 01:26 AM   #76
Oldironracing
Oldironracing's Avatar
Re: GM connect and cruise engine package
Guess no one uses mufflers? Stainless or?
OLDIRONRACING
Oldironracing is offline   Reply With Quote
Old 01-11-2019, 11:18 AM   #77
MIKESAD50
On my LS connect and cruise in the 50 I used 2 1/2" pipe with and x pipe and Stainless Works turbo chambered and it dumps in front of rear tires. Mello when cruising with no drone and gets louder more you step on it. very happy with my set up.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 01-27-2019, 02:02 PM   #78
Oldironracing
Has anyone used a electric push button e brake?
OLDIRONRACING
Old 02-04-2019, 09:14 AM   #79
Oldironracing
Worked on the exhaust this weekend.
OLDIRONRACING
Old 02-04-2019, 09:15 AM   #80
Oldironracing
Exhaust
OLDIRONRACING
Old 02-05-2019, 03:54 PM   #81
Big Moose
Fancy exhaust work, nice!
Big Moose is offline   Reply With Quote
Old 02-12-2019, 11:54 PM   #82
Oldironracing
Thanks. Hope to make hangers this weekend
OLDIRONRACING
Old 02-13-2019, 08:33 PM   #83
bigmoe
bigmoe's Avatar
Is there enough room that the trailing arms won’t come up and hit the mufflers? I was considering tipping my mufflers on their sides to get beside the driveshaft and avoid the trailing arms.
bigmoe is offline   Reply With Quote
Old 02-14-2019, 09:48 AM   #84
Oldironracing
With the rear suspension bottomed out there is a 1.5 inc of clearance. Bottomed out means rear end touching the frame.
OLDIRONRACING
Old 02-14-2019, 09:50 AM   #85
Oldironracing
Has anyone run in to problems with running the exhaust under the trans crossmember with a 4-6 drop?
OLDIRONRACING
Old 02-16-2019, 11:20 AM   #86
gringoloco
A guy with a truck
gringoloco's Avatar
Yes, you will drag it, or worst case, it looks ugly hanging down under the cab. Try an Early Classic, CPP, or similar type and route over it, or weld in humps using steel pipe
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-16-2019, 12:08 PM   #87
bigmoe
bigmoe's Avatar
I bought a straight across crossmember before realizing it would be a problem with exhaust routing. I modified it with the half pipes that are raised up with some flat pieces. I have the same kind of pipe pass throughs at the trailing arm crossmember as you.
Old 07-18-2024, 12:50 AM   #88
Mbeef61
Mbeef61's Avatar
Reviving an old one. Those with connect and cruise or ls swaps. What front accessory drive setups did you go with?
Mbeef61 is offline   Reply With Quote
Old 08-04-2024, 02:12 AM   #89
Richard
On my LSA swap I used an LSX concepts accessory drive.
Richard
Old 08-04-2024, 04:24 PM   #90
LS short box
I use the 2002 Camaro FEA. Some of the stock brackets are no longer available from GM. So I go with ICT.
LS short box is online now   Reply With Quote
Old 08-05-2024, 08:06 AM   #91
A1971Blazer
A1971Blazer's Avatar
I used the stock F-body front drive set-up.
I was able to get the Sanden AC compressor to mount down low and out of sight using the Alan Grove bracket.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 09-30-2024, 02:35 PM   #92
Oldironracing
The truck has been running and put 400 miles on it. Got a po690 code the other day. The relays in the fuss and relay box that come with the kit is getting hot to the point you can’t touch them. Has anyone had this problem?
OLDIRONRACING
Old 09-30-2024, 02:50 PM   #93
Oldironracing
Pictures of box
OLDIRONRACING
