Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-05-2024, 12:05 AM   #1
rwogs
What value fuse is this & what does it do? (Wife's Truck!)
I've been chasing down a bad ground and/or a dirty contact in my wife's 1972 C10 Pickup. While probing around, I accidentally broke a glass fuse that was inside a rubber enclosure near the fusible link and battery. I have not yet dug either end out yet, but can someone tell me what type and amperage fuse it is and what it does? I need to repair it somehow. The vehicle seems to run without it. I've borrowed a couple of images from old posts that show where the fuse/thing is.
Thanks for any help you can give.
1972 Chevy C-10 1/2 ton - "3 on the tree"
rwogs is offline   Reply With Quote
Old 08-05-2024, 12:27 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: What value fuse is this & what does it do? (Wife's Truck!)
Easy answer . that is the fuse for the battery charge indicator,(ampmeter). It is 4 amps and there should be another one over on the left side of the radiator near the horn.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-05-2024, 03:20 PM   #3
rwogs
Sweet! Thanks VetteVet. Next step is to fix that and then pull the steering wheel and check the turn signal switch. I read your post on checking that switch (very good) and it looks like I have an issue with the left turn portion of the switch.
Old 08-06-2024, 07:38 PM   #4
dmjlambert
dmjlambert's Avatar
The size of the fuse is SFE4.
dmjlambert is online now   Reply With Quote
