08-05-2024, 01:19 PM | #4976 |
Re: What did you do to your truck today.The 3rd chapter
08-05-2024, 02:43 PM | #4977 |
Who Changed This?
First time (I think) that I've used this emoji-
08-06-2024, 08:41 PM | #4978 |
Took it out for a lil road time...just tooling on down to the historic McKinney square for lunch/early dinner. My target restaurant was Juarez McKinney...very good stuff! On the way... https://youtu.be/LHw8H-z0HAU?si=XooHN0NULWC-4Ihq For fun... https://youtu.be/vyzf8vNPTZM?si=D1iuyRqY0VqFWA3D -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
08-06-2024, 08:49 PM | #4979 |
nice ride.....
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
08-13-2024, 09:01 AM | #4980 |
Preparing to put the motor from my 72 into the anniversary truck . This motor ran very well not an issue but I did find this changing out the oil pan gasket . Oil pressure never dropped off . Lucky I guess ordered a new Melling pump ,pick up screen and pump shaft . Definitely going to tig the new one when I get the depth set
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 08-13-2024 at 09:47 AM. |
08-13-2024, 09:15 AM | #4981 |
Who Changed This?
I had that happen on a '64 Impala. The oil light came on when slowing down an off ramp. Tapped the pan with a hammer, and it clunked back. Put another quart of oil in it to keep the oil pump gozinta covered with oil and nursed it to my parent's house to pull the engine. One of the neighbors was a machinist and he knurled the part of the screen assembly that presses into the pump. It was a new pump and the old screen that was on the engine prior to rebuilding.
08-13-2024, 12:24 PM | #4982 |
Easiest way is to drive it back in then put a tack weld on it so it will never do that again.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
08-13-2024, 12:53 PM | #4983 |
08-13-2024, 05:18 PM | #4984 | ||
I’m going all new Quote:
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
08-15-2024, 08:50 AM | #4985 |
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-15-2024, 10:24 AM | #4986 |
08-17-2024, 04:49 PM | #4987 |
Got the new parts for the 350 . Nice to know it’s a 4 bolt main engine the plastic sleeve on the drive shaft has seen better days . Glad I got a metal replacement piece
08-17-2024, 06:09 PM | #4988 |
I made some progress last couple a day media blast the surface rust and primed the bottom of the cab floor
08-17-2024, 07:13 PM | #4989 |
Mounted and tried out my 1973 Coleman cooler, son was happy to have cold drinks at the cruise in so its a success.
1972 C10 Step Side short bed |
08-18-2024, 07:55 PM | #4990 |
I bought a set of headlight bezels for $20.
I had been thinking of adding a little black around the bulbs but wasn't sure I'd like it, so I figured I'd sacrifice the new purchase. All in the name of science, they were in OK condition but certainly not mint. So a little time prepping on a rainy day and some low gloss black my curiosity is somewhat satisfied. I'm glad I tried it on a second pair. My original ones are in pretty good shape. I'm not sure I like the results.
I got a bench seat baby, you don't have to sit over there. |
08-18-2024, 08:06 PM | #4991 | |
08-18-2024, 08:54 PM | #4992 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
08-18-2024, 09:11 PM | #4993 |
At the body shop.
Bath time, 1st time in way to long
" That didnt make it any newer " " Dont antique the equipment " |
08-20-2024, 12:03 AM | #4994 | |
'71 Jimmy has an all-chrome grille, and I like it. Black on the bezels might diminish the amount of light going forward. I like to light it up.
08-21-2024, 11:26 AM | #4995 |
Small update... Truck is headed to Arkansas. Hopefully going to get buttoned up in the next month...
08-21-2024, 09:41 PM | #4996 |
Did some more work on the 350 . Innards are nice and clean I am going to do the valve guide seals . Whoever did this motor did some nice work like the stud for the distributor and the punch marks for it . Didn’t like the silicone mess to seal the intake nothing wrong with using it but at least smooth it out .
08-22-2024, 01:30 PM | #4997 |
That's PURDY.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
08-22-2024, 04:28 PM | #4998 |
08-22-2024, 08:26 PM | #4999 |
Got the heads off today intake valves were gummed up from the valve guides leaking . I’ll be dropping the heads off tomorrow to be done .
The pistons were carboned up but came out clean with a little acetone and trans fluid scrubbed with a nylon plush . .040 over so it’s a 355 ci the cylinder walls have no ridge no scoring either
08-22-2024, 08:30 PM | #5000 |
My grandson is getting real good with the tig . I pulled the lifters one at a time and put them back in their respective bores . No real wear on them or the cam .
