Yesterday, 05:29 PM | #1 |
What spark plugs for 1963 230 engine
Hi folks, I am gathering parts so I can clean up the engine, carburetor, distributor and coil, etc. and then I would like to see if this engine will run. The truck has been sitting in a yard since the early 90's and the spark plugs were removed. I haven't done anything serious yet except some external cleaning of mud dobber nests and cobwebs. One spark plug I found was laying in the engine compartment, it is an AC R44LTS6 and I don't know if it came out of this engine. How do I figure out what spark plugs to get? The hole where the spark plug goes has a narrow opening that would accommodate a spark plug with 5/8" hex nut, but I see some listings on O'Reilly Auto Parts and Amazon where the "confirmed fits 1963 C10" show the larger spark plug, I assume that is 13/16 nut. I cleaned the threads on the old unknown spark plug with a wire brush and put some oil on the threads of the engine and installed the spark plug into each of the holes in turn to clean up the threads on the engine.
Yesterday, 10:03 PM | #2 |
Re: What spark plugs for 1963 230 engine
That is the correct type of plug for that engine but I don't believe its the correct number. The parts store should have a listing on it.
Have you tried turning the engine over to see if it is not stuck. Setting that long & with the plugs out it is liable to be frozen. George |
Today, 05:33 PM | #3 |
Active Member
wrong plug should be ac r44xls
https://www.carparts.com/details/Che...B&gclsrc=aw.ds
Old dogs and children and watermelon wine Last edited by dmb; Today at 05:38 PM. |
Today, 05:44 PM | #4 |
Active Member
you can go up to a 46 for a hotter plug, I think they came with a r46n but that is an old number
Old dogs and children and watermelon wine |
Tags |
spark plugs |
