![]() Join Date: May 2006
Antenna
Has anyone successfully managed to take an antenna cable apart. Been looking at it for a couple days and can’t find a way to replace cable
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-29-2024 at 07:18 AM. |
![]() Join Date: Feb 2002
Re: Antenna
[quote=jaros44sr;9330440]Has anyone successfully managed to take an antenna cable apart. Been looking at it for a couple days and can’t find a way to replace cable
![]() You need to find a local Ham shop. CB would have done, but that's archaic now. Get some fresh coax, and have them put a fresh plug on the end.
Re: Antenna
Thanks for your time I'll do a search in my area
Re: Antenna
Never saw the insides dremel tool time
![]() Join Date: Jul 2003
If repairing the original doesn't pan out, this is all available new for around $60.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Re: Antenna
I took mine apart and replaced the cable. You need to pull that strap clamp off and the rubber piece will come off. Then you can see what you need to solder.
Re: Antenna
Thanks guys for the info and. Help, I thought the strap clamp was the ticket but wasn’t sure
Re: Antenna
Re: Antenna
Picture to large
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-01-2024 at 09:33 AM. Reason: Picture |
Re: Antenna
The thing with all coaxial cable [COAX] is that center wire is the HOT lead, that receives or tramsmits signal. The braided sheath of the outboard cable is the Ground. It should be grounded to the chassis on one end and soldered to the outside metal of the plug.
Re: Antenna
Thanks for the advice
Re: Antenna
Able to get rubber boot off with minimal damage to clamp, unsure next step
Re: Antenna
Re: Antenna
#15 |
Re: Antenna
#16 |
Re: Antenna
Nope crises averted just to much glue inhaled while I was building plastic car models
#17 |
Re: Antenna
#18 |
Re: Antenna
You should be able to get a fresh male Antenna Plug like that.*
Strip the Coax back. The center wire is the lead or Hot side. Often made of copper. Solder that inside the thin probe. After peeling back the outer insulation, there's a braided core. That's the Ground side. That should be soldered [or crimped] to the outboard of the plug. [Solder's better] That type plug relies on friction to stay in the radio socket, so bend back the wings on the outside of the plugs for a tighter fit if needed. *Radio Shack might carry it in their online store. Or Francis Wire Works. That type isn't really reusable.
#19 |
Re: Antenna
Thanks for the reply and information, right now having trouble sourcing parts. Will try Ron Francis when he opens up. Maybe radio shack
#20 |
Re: Antenna
![]() Was able to pry gasket off. Letting it soak in WD40for a couple days
#21 |
Re: Antenna
#22 |
Re: Antenna
[quote=jaros44sr;9332734]Better
![]() Looks like there's a lot more to the stock antenna base than aftermarket. The inside part of the non-stock antennas just has a metal ''cage'' to brace against the upper mast. There must be some electronic ''guts'' in the one in the pic. Jim -- Did you get a male radio plug or brand new radio coax lead yet?
#23 |
Re: Antenna
After talking with Wayne at Ron Francis, he mentioned Cruthfield, so on Monday I’ll give them a call
No luck so far in finding cable ends, still sourcing parts There is a plastic piece inside that I would like to clean up, looks kinda tatty, maybe cut half off and slide a sleeve on It looks like it may be swagged on there, I don’t know ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-10-2024 at 09:22 AM. |
#24 |
Re: Antenna
I agree does look a lot beefier then reproduction
![]() This end only has the female plug, I’ll flare the tabs out on Dinah assembly
