Old 08-04-2024, 02:11 PM   #1
Kalums
Question Another carb help...
So... I've got an Edelbrock 1406 that replaced the original QuadraJet ( I didn't do it, it came this way) I rebuilt the 1406...runs amazing, but I get significant rpm drop when I put it in gear (stalling) . Cold or hot it doesn't matter. What gives? I've done a complete tune up, plugs AcDelco R45ts (gapped to 45) new MSD 8mm wires(I know that means insulation) the HEI is a Delco and it is putting out about 15k volts on each lead and wire at the plug(zapped myself a few times testing... Ouch) timing is set to 12 dgrs advanced @ 800 rpm idle. Choke is electric and appears to be working/functional (choke flap is opening slowly as it warms)Vacuum gauge shows good vacuum hot or cold. My vacuum advance is connected to the vacuum port on the passenger side of the carb(swapping to driver's side port only increases in park idle speed) . I've sprayed carb cleaner on ever crack crevice and hose, I can't find a leak if there is one. Everything is set up per the Edelbrock set-up guide and everything I can find from the Google overlords. What am I missing?
Kalums is offline   Reply With Quote
Old 08-04-2024, 03:25 PM   #2
geezer#99
geezer#99's Avatar
Re: Another carb help...
Turn your idle down to 600 rpm.
Then check your timing.
At 800 rpm the mechanical timing might be kicking in,
Old 08-04-2024, 03:43 PM   #3
Kalums
Thank you, I will try that👍
Tried this morning... No go, still does the same thing.
Old 08-05-2024, 12:39 PM   #4
Wrenchbender Ret
Try it with the vacuum advance disconnected.
George
Wrenchbender Ret is offline   Reply With Quote
Old 08-05-2024, 01:32 PM   #5
geezer#99
geezer#99's Avatar
So at 600 rpm, what was your timing?
Old 08-05-2024, 02:53 PM   #6
leftybass209
leftybass209's Avatar
Did it have these symptoms before you rebuilt the Edelbrock?
is it the original cast iron manifold with a carb adapter, or is it a square bore intake manifold?
Where do you have the idle mixture screws set, and do they actually change the vacuum signal/idle speed when you run them in/out?
leftybass209 is offline   Reply With Quote
Old 08-05-2024, 04:11 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Those spread bore to square bore adapters are notorious for air/vacuum leaks.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-05-2024, 08:22 PM   #8
hugger6933
Spray some carb cleaner around the base and listen for RPM changes when you hit the vac leak you have it will rev up. Jim
hugger6933 is offline   Reply With Quote
Old 08-05-2024, 10:39 PM   #9
Kalums
Timing did not change, 12 dgrs advanced.
Old 08-05-2024, 10:40 PM   #10
Kalums
George
Rpm goes up about 40-50rpm but other than that no change.
Old 08-05-2024, 10:45 PM   #11
Kalums
Original manifold with adapter, mixture screws set 1.5 turns "open" after screwing all the way in (snug, not torqued). Yes it starts to lean out if I turn the screws in about 1 full turn and it also starts to run rich/bog if I turn the mixture screws out more than 4 full turns. Vacuum does change significantly either way.
Old 08-05-2024, 10:47 PM   #12
Kalums
I've soaked the manifold/carb/ and anywhere I even think there could be a vacuum connection. No rpm changes... 😩
Old 08-05-2024, 10:50 PM   #13
Kalums
Gary
Not gonna lie, I'm leaning that direction... I just didn't want to spend the $$$ on an entire manifold, my wallet already looks as dry as the desert I live in 😅
Old 08-05-2024, 10:53 PM   #14
Kalums
I understand that the Edelbrock is a much easier carb to tune/rebuild... But I do have the original Quadrajet... Would it be worth my effort to rebuild? Assuming it is rebuildable...
Do they make an electronic choke "upgrade" for the Quadrajet?
Old 08-06-2024, 12:44 AM   #15
Rust_never_sleeps
Rust_never_sleeps's Avatar
I'm thinking you wouldn't get the idle speed down to 600 if there was a vac leak
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 08-06-2024, 12:46 AM   #16
72SB
you really want VA using manifold port, not the timed one. You may have to back down "initial", aka base, timing a few degrees as VA will add some at idle likely. You want 20-24 degrees with VA connected so if VA provides 12 degrees advance, set base at 8.
Fairly classic symptom of bog. die, without VA on manifold vac when put in gear (automatic) if that is what is happening. Eddy carbs are dead simple to tune, basically a Carter AFB
Timed port vac was a failed emission thing. Yeah I know the carb manual says use it, they basically have to. Just plg the timed port and use manifold vac for VA.
Now adjusting VA to come in and how much is a different discussion but the 411 above should resolve the stall issue when put in gear.
Vac leaks typically increase RPM so does not sound like that is happening
72SB is offline   Reply With Quote
Old 08-06-2024, 12:46 AM   #17
Kalums
Don't get me wrong... It was struggling at 550rpm...and ran rough at 600...but it stayed running🤷
Old 08-06-2024, 12:49 AM   #18
Kalums
So... I should disconnect from the carb and connect the VA to the manifold?
I went back and read you post again... And literally walked out to the truck to try this... When I have the VA plugged into the carb (timed port?) it runs rough (like I need new motor mounts... Which I have in the garage) at 12 dgrs advanced (manually set by me using a digital timing light) but if I turn my distributor ever so slightly til it is about 20 dgrs advanced it speeds up my rpms AND runs smoother. I can then turn down my idle to 800 rpm and it only drops to 650-675 when I put it in gear, still a drop but no stalling ...... My light bulb just came on... Was I manually retarding my timing? Too much?? Was I the "malfunction" *face palm*
Old 08-06-2024, 01:04 AM   #19
Kalums
When setting "initial timing" should my VA be connected or disconnected?
Old 08-06-2024, 01:08 AM   #20
Rust_never_sleeps
Sure, but IMLE, with even a tiny vacuum leak, the idle speed just won't drop below 1200, maybe 1k because it's still sucking air through the leak when the plates are closed.
What kind o' ignition are you running, btw
Old 08-06-2024, 01:10 AM   #21
Rust_never_sleeps
Initial timing should be with VA disconnected(and that hose plugged)
Old 08-06-2024, 01:11 AM   #22
Kalums
Stock ignition, aftermarket AcDelco HEI
Old 08-06-2024, 01:15 AM   #23
Kalums
I.... Am an idiot... Or just nieve... It is currently too late for me to futz with this anymore tonight (kids are sleeping and V-8 currently with straight pipes AIN'T quiet) thank you for the assistance, I'm pretty sure you guys figured it out and I just need to put in the work. I will report back tomorrow. Thanks again.
Old 08-06-2024, 08:03 AM   #24
WorkinLonghorn
WorkinLonghorn's Avatar
Here's my 2c. If you have vacuum assisted brakes, try it with that port (and any other vac. ports) on the carb plugged.If that's not it, you need to go back through that Edelbrock and check the idle circuit very carefully. Also, it would help if you answered Leftybass209's question; How did it run before you went through the carb? -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 08-06-2024, 08:32 AM   #25
geezer#99
geezer#99's Avatar
So...
‘ but if I turn my distributor ever so slightly til it is about 20 dgrs advanced it speeds up my rpms AND runs smoother. I can then turn down my idle to 800 rpm and it only drops to 650-675 when I put it in gear, still a drop but no stalling ...... *
That there tells you one thing!
Your timing marks aren’t accurate.
Either the mark on the balancer is wrong or the timing tab is wrong or a combination of both.
You need to find true top dead centre on #1 cylinder to see where your timing tab/balancer marks are at.
