Old Yesterday, 09:08 PM   #1
MacataQ
MacataQ's Avatar
voltage reg problem
GOOD DAY ALL
i have spent the day going thru a ton of posts on Voltage Regulators
and i cant seem to find anything that covers my specific problem. hoping someone here will set me on the correct path electrically (pardon the pun)
1972 c10
SBC 350
3 wire alternator w external Voltage Reg
no A/C no pwr win, stock radio
details
low charging voltage @ bat when go thru stock reg -by pass reg (test) alternator pitting around 14.9 15.4v
i believe this test confirms the alt is okay?
so i suspect the VR
so went online Napa Canada out in my vehicle details and was directed to
purchase VR142SB as exact fit for my truck, so i ordered it.
when i got it a became perplexed
i thought it would be a matter of plug and play .."as in EXACT FIT"
but it doesn't look like it to me
see pics
any ideas?
thanks
Mac
MacataQ is offline   Reply With Quote
Old Yesterday, 10:39 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: voltage reg problem
Originally Posted by MacataQ View Post
GOOD DAY ALL
1972 c10
SBC 350
details
so i suspect the VR
see pics
any ideas?
thanks
Mac
Does the 4-Contact plug fit?
It looks like a slight design change. The contact on the left [in both pix] goes thru a heat dissapating resister to ground on the box itself. In the newer version, there's a terminal for you to attach your own ground lead.
The Factory also had the VR boxes suspended off the Radiator Core Wall with vibration shedding rubber mounts. I have duplicated this effect by stacking rubber plumbers' washers and this may isolate the VR Box from ground, so groundibg is necessary.
To be honest, I had trouble with ''Lifetime Warranty'' replacement parts from O'Reilly's. They bought out Checker Auto and inherited their lifetime warranties, but their replacemts all failed. On my '68 Chevy Stepside, I cannibalized a VR that was on my '67 K/10 Suburban, from 1998. It works fine.
On my '71 GMC Jimmy, I got a wiring conversion kit from M&H, and Got a NIB SI-12 Alternator with internal VR. It's working fine.
Old Yesterday, 10:51 PM   #3
MacataQ
MacataQ's Avatar
orange
thanks for responding
it looks like it lines up correctly
the new one does not have aground on the casing like the old one
Mac
Old Yesterday, 10:55 PM   #4
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
I seem to remember something about polarization of a VR. Touching one of the wires to get it flowing in the right direction. "??????????
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old Yesterday, 10:58 PM   #5
MacataQ
MacataQ's Avatar
70
not sure on that? any details?
Mac
Old Yesterday, 11:43 PM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
following
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old Today, 12:17 AM   #7
1970 CST Short Wide
Senior Moment
70
Mac
This was a long time ago. I remember something about touching Field to Ground. Probably long forgotten due to new Alts with built in Reg ?????
Any body old enough to remember this or am I Dreaming. LOL
I’m only 70 and I think my mind still works OK. ????
Pittsburg Ca
94565
Old Today, 12:30 AM   #8
Rust_never_sleeps
Rust_never_sleeps's Avatar
Mac
Isn't the L-shaped contact on the left spot welded to the case, or is that an optical delusion?
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old Today, 01:46 AM   #9
1970 CST Short Wide
Senior Moment
I’m going to laugh my Ass off if I’m correct here. Do your research, let me know
Pittsburg Ca
94565
Old Today, 02:18 AM   #10
MacataQ
MacataQ's Avatar
Angry Re: voltage reg problem
i have attached another pic hope it shows the L shaped contact better.
im not any better a photographer than electrician!
Mac
Old Today, 02:27 AM   #11
'68OrangeSunshine
It looks like its separated from the rest of the case by a sheet of black plastic. The tip of the L-shape is a male spade terminal for a ground lead with a female spade terminal, a length of wire, and a ring terminal to be connected to the frame or chassis somewhere.
All the VRs I've gotten have a selftapping machine screw w/ 1/4'' hex head that grounds the VR.
As I said earlier, because the rubber mounting grommets isolate the VR from road vibrations may also isolate it from Ground.
Old Today, 02:29 AM   #12
'68OrangeSunshine
Mac
OK. I guessed right.
That's for a Ground lead.
Old Today, 02:46 AM   #13
MacataQ
MacataQ's Avatar
Orange
yes all the contacts seem mounted on the black plastic piece. so i am assuming that L shaped one is going to be the brown wire on the original VR, using the original female
plug.
Mac
Old Today, 02:53 AM   #14
RustyPile
RustyPile's Avatar
This procedure was for polarizing a generator.. Back in the days, some car manufacturers had positive ground systems, others had negative ground systems.. Polarization procedures are not necessary for alternators.
MacataQ, now is your chance to upgrade your charging system. Unless you just want to keep things exactly original, you can install an internally regulated alternator.. Minor wiring modifications and you're in business.. How to do this simple procedure is all over the internet, including our own ELECTRICAL forum.
RustyPile is offline   Reply With Quote
Old Today, 03:18 AM   #15
MacataQ
MacataQ's Avatar
Rust
thanks for the clarification...good to know!
i have the wiring diagram to switch to internal alt for later when i can afford to do that, but since this alternator tested fine & already bought new VR, ill keep using it.now i understand how the whole thing works! installing tm...er today, will report results
thanks
Mac
