Old Today, 12:43 PM   #1
pjmoreland
pjmoreland's Avatar
5k Tach Cluster
Here are the details on this cluster:
Tach - Brand new reproduction
Fuel, Temp, Oil & Battery Gauges - These are nice OE gauges that have been bench-tested. They all function correctly.
Speedometer - This is a nice OE unit. Tested by spinning it with a servo motor at precisely 1001 RPM, and it read 60mph (60mph is perfect). Input shaft lubricated and odometer set back to zero.
Front Tin - OE - Factory-style formed opening added for the tach. Video
Back Tin - OE - Tach hole added using a CNC router based on a pattern made from a factory tach tin. Video
Lens -OE - Dummy tach markings removed, and die-cut decals applied for the 5k tach. The lens is nice, and it has very little in the way of swirl marks or scratches. Video
Bezel - Reproduction 69-72 style from Auto Metal Direct. NOTE: CAN BE SWAPPED OUT FOR A 67-68 STYLE IF YOU WANT
Printed Circuit - Brand new reproduction
Bulbs - Tested good
$375 + shipping
Zelle, Venmo, CashApp or money order only.
Send me a PM or email me at dummyfillernecks@gmail.com if you have any questions.
pjmoreland is offline   Reply With Quote
Old Today, 12:43 PM   #2
pjmoreland
pjmoreland's Avatar
Re: Tach Cluster
More photos
Old Today, 12:45 PM   #3
pjmoreland
pjmoreland's Avatar
Re: Tach Cluster
Light testing
Old Today, 12:45 PM   #4
pjmoreland
pjmoreland's Avatar
Re: Tach Cluster
Fuel gauge testing
Old Today, 12:46 PM   #5
pjmoreland
pjmoreland's Avatar
Re: Tach Cluster
Temperature gauge testing
Old Today, 12:47 PM   #6
pjmoreland
pjmoreland's Avatar
Re: Tach Cluster
Battery and oil pressure gauges
Old Today, 12:48 PM   #7
pjmoreland
pjmoreland's Avatar
Re: Tach Cluster
Speedometer
Old Today, 04:30 PM   #8
Tmend
Tmend's Avatar
Re: 5k Tach Cluster
Very nice work .. I just watched the videos again and again.. so when you going to start knocking out centers from 1/2 ton hubcaps lol… Again great work .
Some progress is better then no progress
Tmend is offline   Reply With Quote
Old Today, 04:34 PM   #9
pjmoreland
pjmoreland's Avatar
Re: 5k Tach Cluster
Thank you
Old Today, 05:55 PM   #10
pjmoreland
pjmoreland's Avatar
Re: 5k Tach Cluster
Sale pending
