Old 08-02-2024, 06:31 PM   #676
dsraven
Re: Yet another GMC build
Hydroboost is awesome.
dsraven is online now   Reply With Quote
Old 08-08-2024, 11:47 AM   #677
6DoF
6DoF's Avatar
hydroboost feels different for sure ... but it's like putting an 6-71 blower on your brake booster! having the stopping power of a rig built to drive around at 12,000gvw, but only rolling 4000, works out reeaaalll nice
6DoF is offline   Reply With Quote
Old 08-08-2024, 11:26 PM   #678
dsraven
AND, its the same all the time unless the engine dies or you blow a hydraulic hose, then you have one boosted brake application before the manual brake feel comes back.
Old 09-29-2024, 04:10 PM   #679
OKGMC4
OKGMC4's Avatar
I was car 454 at the track today. Wanted to see how it went with a new set of drag radials on the rear. Best time was 11.7 and I am happy about that.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 09-30-2024, 01:50 PM   #680
6DoF
6DoF's Avatar
NICE!! hard to complain about a solid 11sec truck!
having issues anywhere, or anything you'd change to try for faster?
Old 09-30-2024, 03:21 PM   #681
OKGMC4
OKGMC4's Avatar
Could go with a stall converter but the radials might not hold anymore. Could also try more timing or boost with E85 but I like running pump gas and also drag radials might not hold. It would either hook or spin a half turn and go. Just about perfect. The Nittos are expensive but work. Plus, because the tech guy passed me without even looking under hood, I was later warned that if I get faster than 11.5 they will require a roll bar installed. Not sure I want that. Yet. Still would like to make it work on a road course. But I need more brakes, lower in the rear which means frame mods, and track tires. How cool would it be to go track with a bunch of Corvettes and BMWs in an ancient pickup truck?
Old 10-01-2024, 09:14 AM   #682
6DoF
6DoF's Avatar
ooooo, i always forget that 11.5 is the breakover ... 11.7 is fawkin MINT!
the cornering game can be a deep hole too. moving weight, alignment adjustments, getting springs/shocks/bars tuned just right. worth it.
Old 10-03-2024, 07:00 PM   #683
Kevin_C
Thats awsome. I live down the road from New England dragway. Hoping to run mine down the track next year.
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 10-04-2024, 03:03 PM   #684
OKGMC4
OKGMC4's Avatar
Can’t wait to see the time slip!
