08-03-2024, 02:13 PM | #51 | |
Who Changed This?
Re: Bought My Uncles '69 Chevy 1/2 Ton Today
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 08-04-2024 at 03:53 PM. Reason: Was 527, corrected to 517. |
08-03-2024, 02:36 PM | #52 |
Oh. My. Gosh!
I had a feeling it was gonna clean up well, but not THAT good! What a stunner! Congrats! EDIT: Best looking “saved” farm truck Ive seen. Most are beat to a pulp…
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. Last edited by slikside; 08-03-2024 at 02:49 PM. |
08-03-2024, 02:56 PM | #53 |
I watch enough Junkyard Digs and Thunderhead289 videos to know what an Iowa farm truck can look like, that one's a pearl
1970 C10 Custom longbed 350/350 Code:
__ ______|__]\____ ....|___(o)_____(o)_] |
08-03-2024, 05:18 PM | #54 |
Always nice to see his work. Leon is a perfectionist ! Congratulations on another fine job…
71 C-20 07 Magnum RT AWD |
08-03-2024, 11:05 PM | #55 |
Moderator
Beautiful truck Leon!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-03-2024, 11:41 PM | #56 |
The Older Generation
Thanks Gentlemen. The paint doesn't look to me like it has any metallic in it. It looks like it's listed as 4517AA on the SPID. I will have to double check it in the morning.
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 08-03-2024 at 11:48 PM. |
08-04-2024, 01:03 AM | #57 |
Looks great .. solid truck. Looking forward to seeing the progress.
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC |
08-04-2024, 01:04 AM | #58 |
Who Changed This?
That would make it a special order color. Maybe compare it to #67 Burgundy Poly from the '69 car line?
https://www.pinterest.com/pin/paint-...0286355039858/
08-04-2024, 02:04 AM | #59 |
Subscribbity-doo!
517 is definitely maroon metallic.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Thank you all so far you are angels!! Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
08-04-2024, 07:18 AM | #60 |
Looking forward to the pics after detailing it!
71 C10 72 K20 72 K10 Super Kirk |
08-04-2024, 12:04 PM | #61 |
Proprietor of Dale's Corner
Very nice! Subbed...
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
08-04-2024, 04:36 PM | #62 |
Beautiful Truck, same color as the one I bought new in the fall of 68, mine was pretty low optioned with just gauges , step bumper, with the 250 and 3 on the tree. You don't get much for $2160.00 out the door, as I remember those 68.00 a month payments weren't always easy back then. I understand that was low option color also..
08-07-2024, 09:48 PM | #63 | |||
I know my eyes aren't the best any more but if it has metallic in it it must be really fine. I polished a couple of places and I will check them out in the sun in the morning. Thanks! Thanks Dale. Quote:
The paint was one of the reasons I wanted this truck so bad. I have always wanted a maroon one. .
08-07-2024, 10:09 PM | #64 |
The carb was leaking gas pretty bad so I decided to pull it off and see what was going on with it. None of the bolts or assembly screws were tight on it. I was glad the nuts on the mounting bolts were not tight because this is what I found when I removed the carburetor from the manifold. I cleaned everything up and went ahead and mounted an old carburetor that I had on it. I gently tightened the mounting nuts up just enough so that the gasket would seal. The goal at this time is to just get it running good enough to be able to move it around the yard. I put the clear filter on it temporarily so I could see if I did a good job cleaning the tank out. So far, so good. It idles really good and makes no strange noises.... .. I will go ahead and rebuild the original two barrel, and I have another manifold if I need it. I am going to swap out the wheels/tires tomorrow with some 17" ones I have so that I can get the stock wheels blasted, primed, & painted and get some new tires mounted on them. .
08-08-2024, 03:49 PM | #65 |
Florida Edition
Congrats Leon! Good things happen to good people.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
08-08-2024, 04:56 PM | #66 |
Leon,
I have successfully removed many of those "skinny" studs, never broke one.. I used vice grips, patience, and penetrant oil. I always tapped those blasted holes that carbon up and installed set screws... This carb heating technology went away in the early 70's, thankfully!!! |
08-08-2024, 05:55 PM | #67 |
Wow, what a nice truck.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
08-08-2024, 09:07 PM | #68 | |
Thanks.
Thanks Dave. .
11-27-2024, 01:59 AM | #69 |
Any updates on the royal red beauty?
11-27-2024, 12:15 PM | #70 |
Amazing that it started right up!. I had no idea that was a factory color, or even close to one. I like the blackwalls and hubcaps.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
11-27-2024, 04:57 PM | #71 | |
I have had some delays but I am pretty much ready to put it in the shop for the winter and get serious about it. I bought an '04 big block Suburban to put my snow plow on and I have spent quite a bit of time updating it and getting it ready. Also getting everything around the place ready for winter.
Also had a 1/2 ton LWB frame that I needed to shorten so I could put the short bed box on it that I have. I just finished that up yesterday. Quote:
11-27-2024, 05:50 PM | #72 |
Lots of near show trucks out there anyway. Even mine's a little too nice to use as a truck. Have to be careful with anything I haul in the bed. But for the first 20+ years I had it, I'd just throw all kinds of stuff back there, and not worry about bed floor, bed sides, and tailgate scrapes and dings.
11-27-2024, 05:53 PM | #73 | |
Yeah, that is why I built the Black Dually as a work truck. I have hauled all kinds of stuff in it already.
11-29-2024, 10:39 PM | #74 |
I haven't been on here in some time, but wow love the truck and the story, congrats on it al working out in yr favor, nice family truck, so blessed to have it still.
Things happen for a reason! |
11-29-2024, 11:32 PM | #75 | |
Thanks Donnie. I am so glad I ended up with it. Now I need to get busy on it....
