New Member
![]() Join Date: May 2024
Junk Yard PS Conversion?
Bad shoulders and the short amount of driving I did in the truck last summer lead me to want PS. Even though I love the simplicity of the truck as it sits.
I see plenty of conversion kits on the thread and install threads. But when I look at RockAuto they show some of the PS pumps as the same part number from 67 through the 80s square bodies. So I am curious, if I pull a steering box and PS pump out of a square body will it bolt up? Understand that I will need a different pulley and pitman. Thanks guys. |
Re: Junk Yard PS Conversion?
What year is your truck and what motor?
Pics of the motor help. Last edited by geezer#99; 08-10-2024 at 02:03 PM. |
![]() Join Date: Feb 2016
For the most part yes. Some where around 77 I believe the fittings on the hoses went metric. (Someone correct me if I've gotten the year incorrect ) But none of the squarebody hoses will work without modification of the inner fender well.
That being said none of the 67-72 hoses currently on the market will work without modification to the hose or the fender well so pick your poison. What year truck? 67's have there own special challenge when adding power steering. Welcome aboard. And please post some pictures our your truck. We do love photos of trucks around here.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Dec 2009
As HO455 mentioned
The later ones have the Metric stuff. Personally, With your swap I would try to stay with the earlier ones. I remember your truck in the welcome post you made. Be sure to pay attention to see if your 327 has the short or long water pump. This will affect the brackets and belt alignment. Also, with yours being a 67 4WD. You will have to add a dimple in the frame. And obviously you will need a 4wd steering box.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#5 | |
New Member
![]() Join Date: Jun 2022
While you're scrounging the salvage trucks, maybe snag a hydroboost while you're at it if you've considered power brakes. Not much more work since you'll already be into the messy part
1970 C10 Custom longbed 350/350 Code:
__ ______|__]\____ ....|___(o)_____(o)_] |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Here is a thread I have saved for when I do mine
https://67-72chevytrucks.com/vboard/...d.php?t=762033 .
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
![]() Join Date: Jun 2005
There are two types of pump, one with a bolt-on pulley and one with a press-on pulley. They are interchangeable with the correct pulley. The earlier reservoirs are rounded and the later reservoirs have squared edges. The pump should fit into either reservoir.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#9 | |
OP you should be able to find pretty much everything used . There are so many conversions to LS that there should be plenty .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#10 | |
#11 | |
New Member
Thanks for the link. When you say they are interchangeable with the correct pulley, do you mean the water pump pulley? Or the same pulleys will work not he bolt-on or press-on pumps? |
