Old 03-24-2024, 04:57 PM   #76
SpudWrench
SpudWrench's Avatar
Re: Father/Son/Friend 63 C10 Build
Lots of great work here. Like the exhaust. Gives me a goal on how I will have mine routed
"Just do it! Dont let your dreams be dreams"
-Shia LaBeouf
SpudWrench is offline   Reply With Quote
Old 03-25-2024, 12:08 PM   #77
cla5675
Thanks, Spud. Good luck with your build.
cla5675 is offline   Reply With Quote
Old 03-29-2024, 08:47 PM   #78
cla5675
Got the bed and hood in place for final mock up. So far so good. A few more items to fabricate in the cab then time for body work and some paint.
Old 08-10-2024, 11:31 PM   #79
cla5675
Got the firewall done and first round of epoxy on the cab interior.
Old 08-11-2024, 03:07 AM   #80
Braunschweiger
You are doing a great job and don't let setbacks discourage you,
it will be a great truck.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 08-11-2024, 02:50 PM   #81
cla5675
Thanks!
Old 08-18-2024, 08:46 PM   #82
cla5675
Got a little more filler work done on the interior this week.
Old 09-03-2024, 10:13 PM   #83
cla5675
Interior is ready for color and sound deadener.
Old 09-06-2024, 08:49 PM   #84
cla5675
Did spray out test of the flat gray single stage. Looks good. Gonna paint the rest of the interior and inner side of the doors this week.
Old 09-09-2024, 10:54 AM   #85
rbruno68
When you sprayed your interior, it looks like epoxy went on all surfaces. After that, did you spray the floor/ front of cab under the dash and the dash/back of cab/roof in different paints? Meaning, did you spray something different on areas that would not be seen or covered vs areas that you will see? Hope that question makes sense.
rbruno68 is offline   Reply With Quote
Old 09-09-2024, 10:21 PM   #86
cla5675
Good eye, bruno. We used SPI gray epoxy "from the dash up" on the areas that will get single stage paint and U-Pol Raptor epoxy "from the dash down" which will all be covered in Dynamat or a similar sound deadener.
Only reason for the two primers is U-Pol takes less time for substrate prep and my buddy wanted to try out the Raptor epoxy. Used the good stuff in areas that will be painted.
Hope that helps.
Troy.
Old 09-10-2024, 08:46 AM   #87
rbruno68
Hope that helps.
Troy.
That definitely helps. I will be working on may cab hopefully soon and was thinking about how much work needs to be done. Not that I want to take short cuts, but for areas that will be covered by carpet/mat or tucked up under the dash, I was wondering if there were different ways of doing it verses the way the dash and other places that will be seen will be done. Thanks for the info.
Rob
