Old 07-27-2024, 04:52 PM   #1
lkt1954
Taillight Fuel Filler Hose Routing
I'm trying to route the filler hose from my tail light filler to my rear mounted tank.
I have a sniper fuel tank with the filler hole in the top lower left corner. I have both a straight filler neck for the tank and one like the picture. Both are 2" in diameter. I plan on going between the bed and the frame rail the up to the filler in the tail light.
I have thought about reducing down to a 1" filler (as that is the size of the end in the tail light. Then get a long filler hose with a 90 degree end to connect.
My concern is enough slope so all the fuel drains into the tank.
Can anyone who has plumbed a tail light filler to a rear mounted tank give me some advise?
Larry
lkt1954 is offline   Reply With Quote
Old 07-28-2024, 03:35 PM   #2
Joyridin
Re: Taillight Fuel Filler Hose Routing
I originally had a 2" set-up, but I could not get the hose to bend tight enough. I had to go to 1.5" diameter. I bought and adapter to go from the 2" to 1.5" from ICT Billet if I recall.
Joyridin is offline   Reply With Quote
Old 07-29-2024, 10:10 AM   #3
lkt1954
Thanks.
Which neck did you use on the tank and what did you use to connect from there to the filler neck?
Old 07-29-2024, 04:54 PM   #4
Joyridin
I am using a Boyd tank and LS Fabrication rear fuel door set-up. I used these hoses:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 08-11-2024, 10:39 AM   #5
TJUCLA98
Do these hoses allow for any bend or are they just for your straight runs?
Also, do you have 2.0" at the tank or at the tail light filler?
Tony J
TJUCLA98 is offline   Reply With Quote
Old 08-11-2024, 11:12 AM   #6
Joyridin
Both allow for bends, but the 2" I could not get it to bend enough to go from tail light to the tank. The 1.5" allowed it without too much of an issue, which is why I went that way. The tail light is 1.5". The hose is 1.5", then I have an adapter right near the tank that adapts the 1.5" hose to 2" as the inlet on the tank is 2".
Old 08-11-2024, 12:18 PM   #7
lkt1954
Joyridin- the hose works perfect.
One question- did you connect the hose to the filler fitting in the housing? If so did you clamp it or just slide it on?
Like you stated the hose is 1.5" and the hole is 1.5", so there is no way to get the hose through with s clamp. I'm thinking putting sealer on the fitting the just sliding the hose on and call it good.
Old 08-11-2024, 02:32 PM   #8
Joyridin
Yes, I have a clamp. I used a kit from LS Fabrication. There is room to clamp it. I also hooked up a vent from the tank to the filler neck. It was a bear, but it works good.
