Exhaust manifold temp
Here's a fun one.
I just put a new 4 row radiator in MY Ad with a 327. Just for curiosity I started checking temps with my temp gun. At the top outlet, the temp shows 177 deg. At the thermostat housing it shows 188. I have cast iron rams horn exhaust manifolds. At the "V" in the middle of the right manifold it shows 217 deg. On the left it shows 422 deg. Does that sound right or should I be checking something? Possible coolant flow problem ? Thanks
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
Re: Exhaust manifold temp
do you have a stuck exhaust butterfly on one side that is forcing all the exhaust through the intake manifold heat riser to the other side?
#3 | |
Good point there if the truck still has the heat riser valve in the exhaust. You should be able to tell real quick by checking the heat of the pipe down the pipes a ways. If the left side is a lot warmer than the right side that is the issue if the right side is still hotter the right side may be running lean but that doesn't fly with most manifolds that feed two cylinders on each side. 188 on the thermostat housing or just above it should mean that you have a 180 Thermostat and life is good temp wise.
no t'stat in it yet and no heat riser in the exhaust. left side is the hottest. Both sides are individual pipes from the manifold to the muffler. I will test temp next time I go for a drive.
Is there a big temp difference between the manifold runners on each cylinder?
dont know - I will check the runner temps hopefully this weekend
OK, Rob. Here's some stats. These were taken with a temp gun with 85 deg outside temps after a run into Yakima.
There is no thermostat installed right now. Carb is an Edelbrock 4 bbl square bore. The manifold is an Edelbrock aluminum, not a high rise or air gap. Left bank cylinder # intake exhaust right bank cylinder # intake exhaust 1 170 370 2 185 460 3 760 4 763 5 165 715 6 170 575 7 495 8 290 ON the intake manifold left front runner 207 left rear 105 ON the right front runner 208 right rear 108 At the "V" where the center exhaust ports come together left side is 760 right is 405 At the exhaust pipe where they enter the mufflers, left is 176 right is 166 What concerns me is that there is such a wide variation in temps. The intake runner temps seem to be close to each other front & back. The concern is the wide variation in temps at the exhaust manifolds Any ideas from anyone would be appreciated.
I'd have to go out and dig my performer intake out of the shed and figure out if he hot exhaust is coming from intake runners feeding off the same side of the carb or same plane of the intake.
Im wondering if I have a coolant flow problem. With the old radiator I never had this problem but I didnt flush the system when I installed the new radiator. Wonder if there is some kind of blockage. Just a thought
remind us why the rad was changed?
If you had a coolant blockage.....what are the temps on the cylinder heads / sides of the block? I think mr48 is on an interesting idea: what is relationship between hot side and the the configuration of the intake runners / carburetor barrels? One side might be running lean (hot) or rich (cold); jet adjustment, mismatch jet sizes, a blockage inside carb. have you pressure tested cooling system? Or checked to see if it holds pressure as it cools after a run. Any bubbles coming up in tank when it is running? (headgasket?) Valves over adjusted on one side of engine might make one side run at a different temperature - but I think it would run badly if it was that badly setup |
rad was replaced because it started leaking after 30 + years. Don't know what the temps on the heads or block are. No bubbles in cooling system. Valves haven't been adjusted in years. May be time to do that. I'm thinking back flush the block, adjust the carb & adjust the valves.
I have an adapter that I can hook a garden hose to the water pump outlet hose and back flush the block that way.
do you run coolant mix or plain water? coolant has antirust properties. a layer of rust is like a layer of insulation
if you have room under there you could pull the block drains and see what comes out and if worried you could remove an expansion plug and see if there is sediment build up in the bottom of the block. as a mechanic I have seen some nightmares in engines that have been neglected by the owners. coolant should be changed every couple of years for this reason and also because the coolant actually turns acidic. have you pulled the spark plugs to see the color of each one? do both exhaust pipes have the same color at their tips-assuming there is dual exhaust are both exhaust pipes/runs/mufflers free flowing, no collapsed baffles, squashed pipes? possibly a complete tune up is in order, valve adjustment, compression test, spark plug replacement, plug wire replacement/resistance check, distributor cap and rotor check/replacement, pcv valve replacement, fuel filter replacement, carb check and tune, timing adjustment and curve check, etc etc |
Im now starting to wonder if I have some kind of blockage in the cooling system. When I put the new rad in, I filled the system with water to check for any leaks. I think I will start with a back flush and then refill with antifreeze. One step at a time
A good working thermostat with air bleed hole might be an idea. I have seen engines run cooler at least on the gauge with thermostat that without. voodoo
#15 |
a thermostat and coolant is recommended because coolant has properties plain water doesn't as well as a thermostat restricts the coolant flow some so coolant has a chance to absorb heat from all areas about the same instead of cooling the higher easier flow areas better than some that flow less easily. also better for controlling heat during start up/warm up where the engine will take longer to get to operating temp, which saves the amount of overfuelling required at that temp, so less fuel washdown of the cylinder walls and pistons and also less oil dilution from that fuel getting past the pistons into the oil pan.
mr48 has a good idea to check the intake plenum under the carb to see if the hot cylinders are fed off the same carb bore. which may possibly be running leaner than the other bore(s). a spark plug color check and exhaust tip residue check may also prove the point to some degree. if it were me I would do coolant pressure test and a rad hose/rad cap check and if that passes it would be followed by a chemical coolant flush followed by a good water flush to rid the system of anything loose. then allow to cool and dump the system completely. pull lower hose off and try to catch what you can so you can see what was in there. then pull the block drains and ensure the block is sediment free. maybe pull an expansion plug if you are not sure, pick a rear one if possible. flush the rad as well to ensure you have good flow from all the tubes if possible. if you run a heater, backflush that as well, removing the hoses of course so no sediment or debris from the heater can enter the engine. when you pull the spark plugs check for any super clean or rusty plugs as that can denote a cracked head. |
