Old 08-10-2024, 12:23 PM   #1
Detour
New Member
Junk Yard PS Conversion?
Bad shoulders and the short amount of driving I did in the truck last summer lead me to want PS. Even though I love the simplicity of the truck as it sits.
I see plenty of conversion kits on the thread and install threads. But when I look at RockAuto they show some of the PS pumps as the same part number from 67 through the 80s square bodies.
So I am curious, if I pull a steering box and PS pump out of a square body will it bolt up? Understand that I will need a different pulley and pitman.
Thanks guys.
Detour is offline   Reply With Quote
Old 08-10-2024, 01:58 PM   #2
geezer#99
geezer#99's Avatar
Re: Junk Yard PS Conversion?
What year is your truck and what motor?
Pics of the motor help.
geezer#99 is online now   Reply With Quote
Old 08-10-2024, 02:07 PM   #3
HO455
HO455's Avatar
For the most part yes. Some where around 77 I believe the fittings on the hoses went metric. (Someone correct me if I've gotten the year incorrect ) But none of the squarebody hoses will work without modification of the inner fender well.
That being said none of the 67-72 hoses currently on the market will work without modification to the hose or the fender well so pick your poison.
What year truck? 67's have there own special challenge when adding power steering.
Welcome aboard. And please post some pictures our your truck. We do love photos of trucks around here.
RIP Bob Parks.
Old 08-10-2024, 02:28 PM   #4
Getter-Done
Getter-Done's Avatar
As HO455 mentioned
The later ones have the Metric stuff.
Personally, With your swap I would try to stay with the earlier ones.
I remember your truck in the welcome post you made.
Be sure to pay attention to see if your 327 has the short or long water pump.
This will affect the brackets and belt alignment.
Also, with yours being a 67 4WD.
You will have to add a dimple in the frame.
And obviously you will need a 4wd steering box.
84 Chevy K-20
Old 08-10-2024, 10:53 PM   #5
Detour
New Member
Truck is a 67' K20 with 327. I posted a couple photos in the new member area a couple of days ago. But here are a couple pictures of the engine/steering as requested.
Old 08-11-2024, 02:01 PM   #6
Rust_never_sleeps
Rust_never_sleeps's Avatar
While you're scrounging the salvage trucks, maybe snag a hydroboost while you're at it if you've considered power brakes. Not much more work since you'll already be into the messy part
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 08-11-2024, 02:10 PM   #7
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Here is a thread I have saved for when I do mine
https://67-72chevytrucks.com/vboard/...d.php?t=762033
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 08-12-2024, 09:01 AM   #8
70STOVEBOLT
70STOVEBOLT's Avatar
There are two types of pump, one with a bolt-on pulley and one with a press-on pulley. They are interchangeable with the correct pulley. The earlier reservoirs are rounded and the later reservoirs have squared edges. The pump should fit into either reservoir.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 08-12-2024, 09:27 AM   #9
72c20customcamper
72c20customcamper's Avatar
I don’t agree I bought this hose for 72 fit was perfect. I had the return line so I just replaced the rubber hose . He would need to either make or buy the hard line ends .
OP you should be able to find pretty much everything used . There are so many conversions to LS that there should be plenty .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-12-2024, 06:21 PM   #10
RustyPile
RustyPile's Avatar
That's the hose I put on my '71 when I converted to power steering.. Mine is a BBC and it fit just fine.. I particularly like the way it routes across the frame, then down the front and back up to the back of the pump.. Very little of the hose is above the frame.
RustyPile is offline   Reply With Quote
Old 08-13-2024, 09:39 AM   #11
Detour
New Member
It has crossed my mind. Would the hydroboost bolt up right between the firewall and master cylinder? Brake lines should flex enough or need new ones?
Thanks for the link.
When you say they are interchangeable with the correct pulley, do you mean the water pump pulley? Or the same pulleys will work not he bolt-on or press-on pumps?
