Old 08-05-2024, 11:02 AM   #201
Chaparralman1974
Chaparralman1974's Avatar
Re: My 1967 Chevy K20 Build Thread
Originally Posted by loudchevy View Post
Clay, Bed sides look great!
Thanks Scott! It is getting there.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old Yesterday, 07:59 AM   #202
Chaparralman1974
8/4/2024 - 8/12/2024
Final priming completed
At this point, I believe that I have the body work on the truck about 98% complete. After applying a full 3 coats of Eastwood Urethane 2K Primer Surfacer on all components of the body, I am now to the final sanding stages before I can apply paint. This past weekend I fixed a flat spot that I found on the bed, and finished up the hood, cowl, and tailgate and then put everything on the frame to fully cure for the next 2 weeks or so. My plan at that point will be to work from the front to the back doing final sanding, fixing any blemishes that I missed and then paint.
As far as paint goes, I have decided to go with TCP Global’s Restoration line of Acrylic Urethane. For the body, I will be going with “Grabber Blue” and will paint the cab “Championship White”. It is rewarding to finally see things coming together.
I did get a bit of overspray on the panels during the priming, so after it was dry, I went over everything with a red scuff pad to knock it down and remove any nibs that were in it. It all gets sanded anyway, but that is the swirling that you see in the primer.
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old Yesterday, 09:15 AM   #203
loudchevy
loudchevy's Avatar
Man that looks great sitting all bolted together looking like a complete truck!
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old Yesterday, 09:18 AM   #204
Chaparralman1974
Thanks Scott! I am doing my best to keep up with you! I am excited at the fact that at some point your '70 and my '67 will hopefully get photographed together at a car show! :-)
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old Yesterday, 09:26 AM   #205
loudchevy
loudchevy's Avatar
Clay
Scott
2003 Tahoe Stock
Old Yesterday, 10:54 AM   #206
Jason Banks
Jason Banks's Avatar
Looking good!
Not sure how the TCP global compares to the PPG Omni AU, but it should be fairly easy to lay down flat, and you can sand out imperfections and buff easily.
Jason Banks is offline   Reply With Quote
Old Today, 10:06 AM   #207
Chaparralman1974
Originally Posted by Jason Banks View Post
Looking good!
Thanks Jason!
I went with the same stuff that Scott (Loudchevy) did on his '70 build. I went over and checked out his truck and the TCP stuff seemed to lay out nicely. I also got the extra slow reducer, and from what I understand that should really help to lay out the paint nicely.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
