Re: Cutting off going down the road
Update - I guess I found the issue, it's been about 3.5 months & still running with no problems (knock on wood).
Cleaned both ground location on block, at front on passenger side & on rear of drivers side - they were both pretty funky. Also cut some length off & put new ring terminal on ground wire from ign coil that was connected at front passenger block location - it was green corroded a few inches up the wire... that was probably the specific issue.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" [B]'85 C10 [B] "Corpse" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
| Bookmarks |
