#40 |
Turning Wrenches Daily
Re: 1964 GMC 3/4 ton build :D
a few updates, still having issues getting the cruise to work have added a resistor in and no luck just yet. Will be coming back to that one when I get some time to research the ECM programming as well. On another note was having stop light cooling issues. Temp was hitting 218-220 at stop lights. I did not have a fan shroud but now I do. I also remixed the coolant. 15% straight anti freeze, distilled water, and some water wetter and doing fantastic at stops. 205 the highest so far
. I emailed PRC and they said yep gives us a couple of weeks and we will have a fan shroud for you. Top knotch company to deal with. Fit is great had to drill 3 bolts holes and add some weather stripping to the top of the chroud but it nice tight and no rattles at all. Trying to save some money at the mooment to get the ac unit charged up. everything electrical on it is working like it should. Lastly will be upgrading the alternator to a bit higher amperage then the 140 amp currently in the truck. Still researching companies on that on. Looking like Ohio or Mechman there.Will post on that once I can afford either one and let yall know how well it works. Cheers Sean Wolff
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!! 1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342 2016 Ram Big Horn 4WD parts hauler 2010 Chevy HHR wife new car after the circled problem blew up!!! 1981 Ram D150 /6 auto Wife's sunday driver Living outside Gladewater Texas now working in Longview at the hospital there future project toys: 1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867
| Bookmarks |
