Old 08-11-2024, 09:17 AM   #1
cfan10
cfan10's Avatar
Cool Alignment
Long story short, I was stuck in the yard in mud...paid my neighbor $30 to pull me out and it bent the tie rod pretty bad...$128 later that was fixed forgot to do a quick alignment and two month old tires are toast.
It's been literally like 7+years since I did this. Which way do the tie rods need to be turned foe toe in/toe out
As always advise is greatly appreciated. Thank you for your time.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 08-11-2024, 09:20 AM   #2
cfan10
cfan10's Avatar
Cool Re: Alignment
Cannot post photos but the driver front tire is slick underneath the car, and thread on the outside. Steering wheel is cocked to the driver wheel to drive straight
Old 08-11-2024, 09:32 AM   #3
cfan10
cfan10's Avatar
Re: Alignment
Photos
Old 08-11-2024, 11:11 AM   #4
cfan10
cfan10's Avatar
Re: Alignment
No one?
Old 08-11-2024, 11:42 AM   #5
kwmech
Re: Alignment
What do you have for steering on that? I see a box, but I also see what appears to be a tie rod end for rack and pinion. Also looks like camber is way off. Take it to an alignment shop and have it all checked out. What year is this?
Old 08-13-2024, 10:35 AM   #6
SCOTI
SCOTI's Avatar
Re: Alignment
The outer Tie Rod on the one side def looks bent.
Clean & put reference marks on the damaged tie rod where it threads into the rest of the linkage (measuring the exposed threads on the damaged part is usually easy enough; a piece of masking tape around the exposed threads works quick & dirty as well).
Remove the damaged part.
Install new part & thread it in as close to the dimension pulled off the one removed.
Reassemble.
For temporary alignment, put the steering wheel straight (which should put your non-damaged side pointing straight). Once that's done turn the turnbuckle in or out as needed to get the repaired side in a similar position as the non-damaged side.
Go get fresh tire/s & an alignment.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-13-2024, 06:54 PM   #7
cadillac_al
Re: Alignment
I just go to an alignment shop when I need one or when I buy another vehicle. If you need one you need one, there is no other way if you care about tire wear.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old Today, 11:01 AM   #8
cfan10
cfan10's Avatar
Cool Re: Alignment
Thanks for the replies, no rack and pinion, power steering gearbox. I replaced the bent tie rods. It was shaking so violently yesterday it scared me terribly. All ofvthese troubles to get pulled out oglf the mud. I think the tow chain was wrapped around the k member
Old Today, 01:00 PM   #9
SCOTI
SCOTI's Avatar
Re: Alignment
With that TRE linkage bent like it was, my guess is it was wrapped around that. They cannot take that sort of pull & retain their shape although if it was wrapped around the x-member, it's possible the TRE was collateral damage depending on the placement of whatever was used to pull you out.
If there should ever be a 'next time', pick a spot on the frame where steering linkage is out of the way.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
