Old 08-19-2024, 09:40 AM   #826
6DoF
6DoF's Avatar
Re: Project: Tow-Rat (Lil' Blue)
one more check mark on the list! one more item added
got the "feet" cut off the job box to make it shorter and got that screwed down into the bed. my front bed lip was just a TAD thick and had the box overlapping the bed door by like 1/4". small trim and good to go. the new list item though is cutting the box down more by sectioning out like 3-4". it doesn't impair my vision out the back, but it's just a bit big/intrusive cosmetically i feel like. that's a figure Matt problem.
a now Matt problem will most likely be a lot of banging and clatter from the box.
front end is jacked up so i change the lower shock bolts. one has rubbed a really bad groove in the pass front tire, it's not nice. i need to get some button head bolts to replace the hex and swap this tire with one of the inner duals.
6DoF is offline   Reply With Quote
