Equal opportunity joke ofender
![]() Join Date: Oct 2011
Broken tap removal
Anybody got a trick to removing a broken 3/8 tap from a hole? Buddy was cleaning up threads in engine block and somehow snapped the tap off.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
Re: Broken tap removal
![]() Join Date: Apr 2016
I'll have to bookmark that, it looks fantastic. It would be most difficult to drill a tap for an easy out. But those look like just the right thing. Let us know how it works out.
laying low
![]() Join Date: Mar 2001
Dang, I could have used that in 1974.
![]() Join Date: Dec 2009
If that set works, you will be money ahead.
Here is the set like that I am used to. Link: https://www.amazon.com/Walton-Tools-.../dp/B0006NGGCM You can also make a chisel out of an old tap with a Cupped shape on the inside. I can send a Picture if you're interested in that idea. Carbide is the best thing for get HSS taps out. But carbide prefers a Ridgid setup or it with chip and break. Dremel tool with carbide Deburring tool works also especially if it cannot be setup in a milling machine.
#6 | |
![]() Join Date: Oct 2014
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
![]() ![]() Join Date: May 2015
If that doesn't work it may need to go to a machine shop and be edm removed...
This is so Ironic to me.
Just this Last Friday I had a Critical job, This stuff needs to be Approached with Kitten gloves (Most of the Time). Thursday evening, I got a call from my (Direct boss) manager. We worked together to get this fixed. I put a Keen Sert in a hydraulic Block that has No replacement part # This was for a Major Car manufacturing Facility. It was for a 5/8 x11 and was taped to 7/8 x 14 for the keen sert.
![]() ![]() Join Date: Jan 2005
I've removed broken off exhaust manifold bolts by welding a nut to them. Maybe this technique would work with a broken tap.
I am not sure what he used but he did text me a picture saying he was able to get it out. I will ask him when I see him next what he did.
#11 | |
The old nut welding trick has saved many a person, including myself. Back when I was just trying to get mine running this was the result of trying to change out the thermostat.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
The weld-a-nut trick works good on bolts...not so much on taps and driĺls..their hardness makes them crystallize if you weld on the hardened parts
So I talked with him again and he used some gun oil squirted in then used a punch to tap it out. He said it worked pretty good like the oil was helping float it out
